vl-list->string, hex notation, and oh god why I can't write this string to a file
How's it going everybody?
Today I write because I have been banging my head against a wall trying to find out why I can't write the output of a vl-list->string to a text file.
I have a list that's equal to (0 1 2), I run that through vl-list->string and get the ASCII codes as a string in the form of "\000\001\002" as the output. So I then save that string to a variable, say, VariableWithString. All good so far.
When I attempt to write this string of ASCII codes to a file using (write-line VariableWithString File) what gets written to the file is just a blank new-line (other write-line statements get written fine.) Not so good now, but I figure I could fix it.
Well I can't really figure it out :wacko:
At first I figured there was some escape character shenanigans going on, so I tried to append extra \'s to the string. vl-string-translate wasn't able to pick up on the existing \'s however.
I have made some progress, such as noticing that a statement such as (vl-string-translate "0" "/0" VariableWithString) will actually replace the \000 with just a plain 0, but this solution makes later coding a bit more difficult/tedious cause the initial list can vary in size quite a bit. I'd very much like to be able to get the exact string, that whole "\000\001\002" written to the file so I can later just do a quick vl-string->list to get my list back, or at the least a version of the string that I could easily restore to the proper form to get my list back.
And I figure it's worth mentioning I'm on BricsCAD
Thanks ahead of time all for any help/insight you can offer!
That is a list of integers they need to be converted to strings to be written to a file.
(foreach x lst
  (if (numberp x)
    (writeline (rtos x 2 0))
    (writeline x)
Edited by mhupp
number checking
  • Thanks 1
Oh hey, yeah, that actually works quite well. I was definitely too deep into the vl-list->string rabbithole and wasn't thinking about just breaking down my list into strings using another method lol :ouch:
We've all been I'm sure lol :beer:
