rlx Posted October 11, 2022 Posted October 11, 2022 (edited) ;;; switch layer Rlx 11-oct-2022 (defun c:swl ( / _laylist lay-list pos max-pos done inp) (vl-load-com) ;;; (setq l (_laylist)) (defun _laylist ( / d r) (while (setq d (tblnext "layer" (null d)))(setq r (cons (cdr (assoc 2 d)) r))) (reverse r)) (setq lay-list (_laylist) pos (vl-position (getvar "clayer") lay-list) max-pos (1- (length lay-list))) ;;; make list with layer filters (setq lwf (_grouplayerfilterswlayernames)) (princ "\nSwitch layer (Lmouse or - = prev , Rmouse or + = next , f = filter , anyother key = exit)") (princ (strcat "\nCurrent layer is " (getvar "clayer"))) (setq done nil) (while (not done) (setq inp (vl-catch-all-apply 'grread (list nil 4 1))) (if (vl-catch-all-error-p inp) (setq done t ) (cond ;;; - or lmouse ((or (equal inp '(2 45)) (= (car inp) 3)) (if (> pos 0) (progn (setq pos (1- pos)) (setvar "clayer" (nth pos lay-list)) (princ (strcat "\rCurrent layer : " (getvar "clayer") " ... "))) (princ (strcat "\rYou've reached the first layer ( "(getvar "clayer") " ) ")) ) ) ;;; + or rmouse ((or (equal inp '(2 43)) (= (car inp) 25)) (if (< pos max-pos) (progn (setq pos (1+ pos)) (setvar "clayer" (nth pos lay-list)) (princ (strcat "\rCurrent layer : " (getvar "clayer") " ... "))) (princ (strcat "\rYou've reached the last layer ( "(getvar "clayer") " ) ")) ) ) ;;; F or f ((or (equal inp '(2 70)) (equal inp '(2 102))) (use_layer_filter)) (t (setq done t)) ) ) ) (princ) ) (defun use_layer_filter ( / lwf inp) (cond ((not (vl-consp (setq lwf (_grouplayerfilterswlayernames)))) (alert "This drawing has no layergroups")) ((not (setq inp (cfl (cons "All" (mapcar 'car lwf))))) (princ "\nLayer group selection cancelled")) (t (if (not (eq inp "All")) (setq lay-list (cadr (assoc inp lwf))) (setq lay-list (_laylist))) ) ) ;;; filtered list will have different length then total list so reset pos & pos-max (setq max-pos (1- (length lay-list))) (if (member (getvar "clayer") lay-list) (setq pos (vl-position (getvar "clayer") lay-list)) (setq pos 0)) (setvar "clayer" (nth pos lay-list)) (princ (strcat "\rCurrent layer : " (getvar "clayer") " ... ")) ) ; choose from list (cfl '("1""2""3")) (defun cfl (l / f p d r) (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ "cfl:dialog{label=\"Choose\";:list_box{key=\"lb\";}ok_cancel;}" p)(not (setq p (close p))) (< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb")(mapcar 'add_list l) (end_list) (action_tile "lb" "(setq r (nth (atoi $value) l))(done_dialog 1)")(action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")(action_tile "cancel" "(setq r nil)(done_dialog 0)") (start_dialog)(unload_dialog d)(vl-file-delete f)))(cond ((= r "") nil)(r r)(t nil))) ;;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/retrieve-layer-names-from-group-layer-filter/td-p/8805768 ;;; Lee Mac / RJP » 2019-05-21 added list of layer names associated with filter (defun _grouplayerfilterswlayernames nil ((lambda (foo)(foo (entget (cdr (assoc 330 (entget (tblobjname "layer" "0"))))))) (lambda (enx / dic i itm rtn) (and (setq dic (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") enx)))) (setq dic (cdr (assoc -1 (dictsearch dic "aclydictionary")))) (while (setq itm (dictnext dic (not itm))) (if (= "AcLyLayerGroup" (cdr (assoc 1 itm))) (setq i (assoc 300 itm) rtn (cons (list (cdr i)(mapcar '(lambda (y) (cdr (assoc 2 (entget (cdr y)))))(vl-remove-if '(lambda (x)(/= 330 (car x)))(member i itm)))) rtn)))))(reverse rtn)))) You now have letter f (or F) for filter (thanx Lee/Ron for example code I found with google) Edited October 11, 2022 by rlx 1 Quote
mhupp Posted October 11, 2022 Posted October 11, 2022 Nice to see my fav dragon kicking around. Quote
rlx Posted October 11, 2022 Posted October 11, 2022 12 minutes ago, mhupp said: Nice to see my fav dragon kicking around. Thank you mhupp , don't have so much time to code anymore but just wanted to see if my last remaining functional braincell was still working you know Quote
