Hi again, while i work on piping in a mechanical plumbing i need to number the pipes which already has text on all the lines , i need to seperate all the lines text by consecutive increases , for example there are 10 texts writing A,B, XY, ...etc. , i will convert them to 1,2,3,4, ... respectively by only clicking them with mouse in order, i dont think i can do it with autocad's TCOUNT command but can we modify the lisp or can anyone help to make a lisp?
i need this because Autocads TCOUNT numbers them by x or y axis but in my drawings lines are not in order in x or y axis , they are in mixed places
so the easiest way to select them in order is by mouse clicking i think
Try this. copied and pasted from what I use but it might complain if I haven't copied everything you need.
Set the first text to the first number you want it to be, then the command ctx+, select the first text and then subsequent texts will be incrementally numbered. Should do numbers or letters but letters will only increment for the last character (A -> Z then back to A again).
(defun c:ctx+ ( / increment )
  (if (= increments nil) (setq increments 1))
  (setq endloop "No")
  (setq sel "1")
  (while (= endloop "No")
    (initget "4 3 2 1 0 -1 -2 -3 -4 Exit")
    (setq sel (nentsel (strcat "\nSelect Text or Enter Text Increment (" (itoa increments) ") [3/2/1/0/-1/-2/-3/Exit]: ") ) )
    (cond
;;      (  (null sel)(princ "\nMissed! Select text, enter increment or press <escape> or 'E'\n") )
      (  (null sel)(setq endloop "Yes") )
      (  (= "Exit" sel)(princ)(exit) )
      (  (= "-3" sel)(setq increments (atoi sel)) )
      (  (= "-4" sel)(setq increments (atoi sel)) )
      (  (= "-2" sel)(setq increments (atoi sel)) )
      (  (= "-1" sel)(setq increments (atoi sel)) )
      (  (= "0" sel) (setq increments (atoi sel)) )
      (  (= "1" sel) (setq increments (atoi sel)) )
      (  (= "2" sel) (setq increments (atoi sel)) )
      (  (= "3" sel) (setq increments (atoi sel)) )
      (  (= "4" sel) (setq increments (atoi sel)) )
      (  (if (and (cdr (assoc 1 (entget (car sel))))(wcmatch (cdr (assoc 0 (entget (car sel)))) "TEXT,MTEXT,ATTRIB") ) (setq endloop "Yes")) )
      (  (if (not (wcmatch (cdr (assoc 0 (entget (car sel)))) "TEXT,MTEXT,ATTRIB") ) (princ "\nThats not text...\n")) )
  ) ;;end while
  (setq endloop "No")
    (setq ent (car sel))
    (setq entlst (entget ent))
    (setq base (cdr (assoc 1 entlst)))
    (if (= increment nil) (setq increment increments))
  (while
      (setq sel (nentsel "\nSelect Text to Replace and Increment: ") )
      (cond
    ) ;;end while
    (uprev base sel increment)
    (setq endloop "No")
    (setq increment (+ increment increments))
  );;end while
(defun uprev (base sel increments / ent entlist currentrevision revlength revisionprefix anumber ones tens hundreds thousands leadingzero dday mmonth yyear yyyear daysinmonth monthlength revcode revletter increaseby sel endloop)
  (setq currentrevision (cdr (assoc 1 entlst)))
  (setq currentrevision base)
  (setq revlength (strlen currentrevision)) ;;length of selected revision
  (setq revisionprefix "")
  (setq anumber 0)
;;date processing
  (setq dday "")
  (if (and (or (= revlength 8)(= revlength 10))(or (if = (wcmatch currentrevision "??/??/*") t)(if = (wcmatch currentrevision "??.??.*") t)))
      (setq dday (atoi (substr currentrevision 1 2)))
      (setq mmonth (atoi (substr currentrevision 4 2))) ;; as integer
      (setq yyear (atoi (substr currentrevision (- revlength 1) 2))) ;; last 2 digits as integer.
      (setq ddaysinmonth (list 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 1))
      (setq daysinmonth (list 31 28 31 30 31 30 31 31 30 31 30 31))
      (setq monthsinyear (list 1 2 3 4 5 6 7 8 9 10 11 12 1))
      (setq yyyear (atoi (substr currentrevision 7 2)))
      (if (= revlength 10)(setq yyyear (itoa yyyear)))(if (= revlength 8)(setq yyyear "")) ;; works out for 'nnxx' in date
      (setq monthlength (nth (- mmonth 1) daysinmonth)) ;;days in the month
      (if (and (= mmonth 2)(= (float (/ yyear 0.4)) (* (fix (/ yyear 4)) 10) ) )(setq monthlength 29)) ;; corrects for leap year
      (setq ddaysinmonth (subst 1 (+ monthlength 1) ddaysinmonth) ) ;; days in the month
      (setq acount increments)
      (while (< 0 acount) ;;if increase rev
        (setq dday (nth dday ddaysinmonth)) ;;increase day by 1
        (if (= dday 1) (setq mmonth (nth mmonth monthsinyear)) ) ;;if day went to 1st, increase month
        (if (and (= dday 1)(= mmonth 1)) (setq yyear (+ yyear 1)) )
        (if (= 100 yyear)(if (/= "" yyyear)(setq yyyear (itoa (+ 1 (atoi yyyear))))))
        (if (= 100 yyear)(setq yyear 00))
        (setq acount (- acount 1))
      ) ;end while
      (while (> 0 acount) ;;if decrease rev
        (setq dday (- dday 1)) ;;decrease day by 1
        (if (= 0 dday)
            (setq mmonth (- mmonth 1))
            (if (= mmonth 0)
                (if (= yyear 0)
                    (setq yyear 100)
                    (if (/= "" yyyear) (setq yyyear (itoa (- (atoi yyyear) 1))))
                (setq yyear (- yyear 1))
                (setq mmonth 12)
            (setq dday (nth (- mmonth 1) daysinmonth))
        (setq acount (+ acount 1))
      ) ;end while
      (if (> 10 yyear)
          (if (/= "" yyyear) (setq yyyear (itoa (* 10 (atoi yyyear))) ))
          (if (= "" yyyear) (setq yyyear "0"))
      (setq breaker "/")
      (if (= (vl-string-search "." currentrevision) 2) (setq breaker "." ) )
      (setq revletter (strcat (cond ((< dday 10) "0")(t "")) (itoa dday) breaker (cond ((< mmonth 10) "0")(t "")) (itoa mmonth) breaker yyyear (itoa yyear)       ))
;;;end of date processing
;;number processing
(if (= dday "")(progn
  (if (< 0 revlength)(progn
      (setq ones (substr currentrevision revlength))
      (if (numberp (read ones))(setq anumber 1))
  (if (< 1 revlength)(progn
      (setq tens (substr (substr currentrevision (- revlength 1) 2 ) 1 1))
      (if (and (= 1 anumber) (numberp (read tens))) (setq anumber 2))
  (if (< 2 revlength)(progn
      (setq hundreds (substr (substr currentrevision (- revlength 2) 2 ) 1 1))
      (if (and (= 2 anumber) (numberp (read hundreds))) (setq anumber 3))
  (if (< 3 revlength)(progn
      (setq thousands (substr (substr currentrevision (- revlength 3) 3 ) 1 1))
      (if (and (= 3 anumber) (numberp (read thousands))) (setq anumber 4))
;;work out numerical revision.
  (if (> anumber 0)
      (setq revnumber (substr currentrevision (- revlength (- anumber 1)) anumber))
      (setq revnumber (itoa (+ increments (read revnumber)))) ;;increase rev number by 1
      (if (and (> revlength anumber)(/= revlength anumber))
        (setq revisionprefix (substr currentrevision 1 (- revlength anumber))) ;;first characters of revision
      ;;fix leading zeros
      (setq leadingzeros (- anumber (strlen revnumber)))
      (if (= 3 leadingzeros)(setq leadingzero "000"))
      (if (= 2 leadingzeros)(setq leadingzero "00"))
      (if (= 1 leadingzeros)(setq leadingzero "0"))
      (if (> 1 leadingzeros)(setq leadingzero ""))
      (setq revletter (strcat revisionprefix leadingzero revnumber))
;;Work out letters revisions
  (if (= anumber 0)
      (setq revcode (+ increments (ascii ones))) ;;increase rev letter by 1
      ;;set exceptions here
;      (if (= 73 revcode)(setq revcode 74)) ;;I  ;;USED FOR DRAWING REVISIONS WHERE I AND O AREN'T USED
;      (if (= 79 revcode)(setq revcode 80)) ;;O
;      (if (= 105 revcode)(setq revcode 106)) ;;i
;      (if (= 111 revcode)(setq revcode 112)) ;;o.. its of to work we go.
      (if (= 91 revcode)(setq revcode 65)) ;;Z -> A. Won't increment 'tens' value
      (if (= 123 revcode)(setq revcode 97)) ;;z -> a Won't increment 'tens' value
      (setq revisionprefix (substr currentrevision 1 (- revlength 1))) ;;first characters of revision
      (setq revletter (strcat revisionprefix (chr revcode)))
));; end of number processing
  (setq entlst (subst (cons 1 revletter) (assoc 1 entlst) entlst))
  (entmod entlst)
  (entupd ent)
  (setvar "CMDECHO" 0)
  (command "regen") ;;in case of nested blocks
  (setvar "CMDECHO" 1)
It is easier and quicker if say if always A -> 1, B -> 2 and so on, then can build up the LISP from a selection and change the texts all at once rather then selecting one at a time
