Dear all:
I would like to know if it is possible.
create a leader from a DIMSTYLE
I mean touch a dimension and to create a MLEADER STYLE  that is called the same way that DIMSTYLE  with the same characteristics .example: arrow size,
text size , color.
I hope you can help me.
test.dwg
I'm not quite sure you need a LISP for this.
Match properties (matchprop) command should do that between dimensions and leaders, or if you set them to the same dim style in the properties box should also do the same
use that command (matchprop) and it does not apply the properties at mleader.
in this dwg create a mleader with the standard style.
try to change its properties.
test 2.dwg
