sadefa Posted September 28, 2022 Share Posted September 28, 2022 Hello to all. I am complete lame about lisp programing. I need some help for automation of process I do manually and it’s driving me crazy. I have a dynamic block, which has multiple custom properties – distances, which can be adjusted. Two of them are to adjust the distance from already present marks. The present marks are placed every 5 meters. The first one starts at 0 coordinate on X axis, so that they are placed on 0, 5, 10, 15, etc. What I am looking for is a way to select multiple blocks and ask them to adjust the distances so that they end at the already known marks. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
mhupp Posted September 28, 2022 Share Posted September 28, 2022 Need a sample drawing with said blocks. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted September 28, 2022 Share Posted September 28, 2022 yes, a DWG example please Because what you ask for is quite probably easily doable Quote Link to comment Share on other sites More sharing options...
sadefa Posted September 28, 2022 Author Share Posted September 28, 2022 Hello, attached a sample DWG. Sample dwg.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 29, 2022 Share Posted September 29, 2022 My $0.05 why not just have the vertical lines based on character and how many, have a make function and an update function, just lines and text. There is a dynamic block drag and get more example, but read text val for spacing not sure. Could do a block attribute rather than text. 5 5 5 5 5 5 5 5 5 5 5 3 2 5 5 5 5 etc. Dynamic block would be fixed how many at moment is 17 what happens with 5 5 5 5 4 3 5 5 6 2 5 5 and so on.the 4 3 is 2 not 1, can see problems. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted September 29, 2022 Share Posted September 29, 2022 I'm not sure if this is how you like the script to help you. Try it out, see if you want it differently. (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; http://www.lee-mac.com/dynamicblockfunctions.html ;; Set Dynamic Block Visibility State - Lee Mac ;; Sets the Visibility Parameter of a Dynamic Block (if present) to a specific value (if allowed) ;; blk - [vla] VLA Dynamic Block Reference object ;; val - [str] Visibility State Parameter value ;; Returns: [str] New value of Visibility Parameter, else nil (defun LM:SetVisibilityState ( blk val / vis ) (if (and (setq vis (LM:getvisibilityparametername blk)) (member (strcase val) (mapcar 'strcase (LM:getdynpropallowedvalues blk vis))) ) (LM:setdynpropvalue blk vis val) ) ) ;; Set Dynamic Block Property Value - Lee Mac ;; Modifies the value of a Dynamic Block property (if present) ;; blk - [vla] VLA Dynamic Block Reference object ;; prp - [str] Dynamic Block property name (case-insensitive) ;; val - [any] New value for property ;; Returns: [any] New value if successful, else nil (defun LM:setdynpropvalue ( blk prp val ) (setq prp (strcase prp)) (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (progn (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x)))) (cond (val) (t)) ) ) ) (vlax-invoke blk 'getdynamicblockproperties) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; http://www.lee-mac.com/attributefunctions.html ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Dynamic Block Distance lisp Adjustment (defun dbda ( ss lft rgt / i blk ) (setq i 0) (repeat (sslength ss) (setq blk (vlax-ename->vla-object (ssname ss i))) ;; TO DO: see if the block is "X_block" (LM:setdynpropvalue blk "Distance1" lft) (LM:vl-setattributevalue blk "X1" (itoa lft)) (LM:setdynpropvalue blk "Distance2" rgt) (LM:vl-setattributevalue blk "X2" (itoa rgt)) (setq i (+ i 1)) ) ) (defun c:dbda ( / ss lft rgt ) ;; user set values and select objects (setq lft (getint "\nLeft value: ")) (setq rgt (getint "\nRight value: ")) (setq ss (ssget (list (cons 0 "INSERT")))) (dbda ss lft rgt) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
