Hi all, Recently , I working with dimention for 3D object.  i can  dimmention it, however it will time to setup . I find an app in autodesk store that can help me, but now it Compatible with 2021 and lower version. So someone can help me a lisp can working with 2022 or higher.
This is link app in autodesk store .
https://apps.autodesk.com/ACD/en/Detail/Index?id=3107263986115458505&appLang=en&os=Win32_64
Thank you !
Just modify the XML file to suit your AutoCAD version if you have experience with such files otherwise contact Autodesk to help you.
