katto01 Posted September 23, 2022 Posted September 23, 2022 Hello, I am trying to get all the properties of all objects in a drawing. In the code attached, I was able to get most of the properties except the most important ones the circle, startpoint and endpoint coordinates. Any ideas? Thank you zwcad_get-all_properties_code.txt Quote
PeterPan9720 Posted September 23, 2022 Posted September 23, 2022 (edited) Hi, I didnt open the code but what do you mean with starting and end point circle coordinate? I know you can get center point, diameter but I don't know about starting and ending point. See for example link https://www.engram9.info/autocad-2006-vba/acadcircle-object-properties.html Edited September 23, 2022 by PeterPan9720 Quote
PeterPan9720 Posted September 23, 2022 Posted September 23, 2022 Sorry to reply again, please could you share the structure ZcadEntity ? Thank you Quote
katto01 Posted September 23, 2022 Author Posted September 23, 2022 please see attached what I need is to get the same full information about all the entities in the dwg 20220920_1134_End_Tapered_wire_Helix_with_parasitic_element.dwg Quote
PeterPan9720 Posted September 23, 2022 Posted September 23, 2022 Thank you for file but I asked for right variable type mentioned in the code not for the dwg. In any case please check the complete code because what has been attached it's not working as it is. Some parts are mussing. Quote
BIGAL Posted September 25, 2022 Posted September 25, 2022 Something like this maybe ;;;===================================================================; ;;; DumpIt ; ;;;-------------------------------------------------------------------; ;;; Dump all methods and properties for selected objects ; ;;;===================================================================; (defun C:Dumpit ( / ent) (while (setq ent (entsel)) (vlax-Dump-Object (vlax-Ename->Vla-Object (car ent)) ) ) (princ) ) Or (entget (car (entsel "\nPick object"))) Oh yeah text file is missing a P at start. Quote
PeterPan9720 Posted September 25, 2022 Posted September 25, 2022 Hi @katto01 Reading the dwg I found arcs not circles as you wrote in your message, so you can try to use the below code specific for arc object. In the same way with <OR> and <AND> function changing the dxf code "Arc" with another object type you can found all objects into the drawing. Public Sub ArcDetail() Dim oSS As AcadSelectionSet Dim oArc As AcadArc Dim iFilterCode(0) As Integer Dim vFilterValue(0) As Variant On Error Resume Next Application.ActiveDocument.SelectionSets("Arcs").Delete On Error GoTo 0 Set oSS = Application.ActiveDocument.SelectionSets.Add("Arcs") iFilterCode(0) = 0: vFilterValue(0) = "Arc" oSS.SelectOnScreen iFilterCode, vFilterValue If oSS.Count Then For Each oArc In oSS With oArc MsgBox "StartPoint: " & .StartPoint(0) & ", " & .StartPoint(1) & ", " & .StartPoint(2) & vbCrLf & _ "EndPoint : " & .EndPoint(0) & ", " & .EndPoint(1) & ", " & .EndPoint(2) End With Quote
katto01 Posted September 28, 2022 Author Posted September 28, 2022 On 9/25/2022 at 3:36 AM, PeterPan9720 said: Hi @katto01 Reading the dwg I found arcs not circles as you wrote in your message, so you can try to use the below code specific for arc object. In the same way with <OR> and <AND> function changing the dxf code "Arc" with another object type you can found all objects into the drawing. Public Sub ArcDetail() Dim oSS As AcadSelectionSet Dim oArc As AcadArc Dim iFilterCode(0) As Integer Dim vFilterValue(0) As Variant On Error Resume Next Application.ActiveDocument.SelectionSets("Arcs").Delete On Error GoTo 0 Set oSS = Application.ActiveDocument.SelectionSets.Add("Arcs") iFilterCode(0) = 0: vFilterValue(0) = "Arc" oSS.SelectOnScreen iFilterCode, vFilterValue If oSS.Count Then For Each oArc In oSS With oArc MsgBox "StartPoint: " & .StartPoint(0) & ", " & .StartPoint(1) & ", " & .StartPoint(2) & vbCrLf & _ "EndPoint : " & .EndPoint(0) & ", " & .EndPoint(1) & ", " & .EndPoint(2) End With thanks will try Quote
katto01 Posted September 28, 2022 Author Posted September 28, 2022 can one define a variable as "Type of" and use it in a loop? something like : dim var as Typeof For Each ent In ThisDrawing.ModelSpace If TypeOf ent Is var Then dothings endif next Quote
PeterPan9720 Posted September 28, 2022 Posted September 28, 2022 Hi TypeOf will be used to check the object type See https://forums.autodesk.com/t5/vba/name-of-type-of-entity/td-p/2085403 Quote
PeterPan9720 Posted September 28, 2022 Posted September 28, 2022 This is another example of TypeOf right use. I never seen a code like shared by you in the post before. For Each Object In ThisDrawing.ModelSpace If TypeOf Object Is AcadBlockReference Or TypeOf Object Is AcadBlock Then 'DO SOMETHING Quote
BIGAL Posted September 28, 2022 Posted September 28, 2022 I know you want VBA but this is a lisp that gets properties of an object, the idea is say get a pline then you can choose which properties you want, you can see how each type of object has different properties available. Just a comment VBA can call a lisp, likewise a lisp can run a VBA. ; properties use as a library function ; By Alan H july 2020 (defun cords (obj / co-ords xy ) (setq coordsxy '()) (setq co-ords (vlax-get obj 'Coordinates)) (setq numb (/ (length co-ords) 2)) (setq I 0) (repeat numb (setq xy (list (nth (+ I 1) co-ords)(nth I co-ords) )) (setq coordsxy (cons xy coordsxy)) (setq I (+ I 2)) ) ) (defun AH:chkcwccw (obj / lst newarea) (setq lst (CORDS obj)) (setq newarea (/ (apply (function +) (mapcar (function (lambda (x y) (- (* (car x) (cadr y)) (* (car y) (cadr x))))) (cons (last lst) lst) l)) 2.) ) (if (< newarea 0) (setq cw "F") (setq cw "T") ) ) ; Can use reverse in Autocad - pedit reverse in Bricscad. (defun plprops (obj lst / ) (foreach val lst (cond ((= (strcase val) "LAY") (setq lay (vla-get-layer obj))) ((= (strcase val) "AREA")(setq area (vla-get-area obj))) ((= (strcase val) "START")(setq start (vlax-curve-getstartpoint obj))) ((= (strcase val) "END" (strcase txt))(setq end (vlax-curve-getendpoint obj))) ((= (strcase val) "LEN" (strcase txt))(setq len (vlax-get obj 'Length))) ((= (strcase val) "CW" (strcase txt))(AH:chkcwccw obj)) ((= (strcase val) "CORDS" (strcase txt))(CORDS obj)) ) ) ) (defun lineprops (obj lst / ) (foreach val lst (cond ((= (strcase val) "LAY") (setq lay (vlax-get obj 'layer))) ((= (strcase val) "START")(setq start (vlax-get obj 'startpoint))) ((= (strcase val) "END" (strcase txt))(setq end (vlax-get obj 'endpoint))) ((= (strcase val) "LEN" (strcase txt))(setq len (vlax-get obj 'Length))) ) ) ) (defun circprops (obj lst / ) (foreach val lst (cond ((= (strcase val) "LAY") (setq lay (vlax-get obj 'layer))) ((= (strcase val) "LEN" (strcase txt))(setq len (vlax-get obj 'Circumference))) ((= (strcase val) "RAD" (strcase txt))(setq rad (vla-get-radius obj))) ((= (strcase val) "CEN" (strcase txt))(setq cen (vlax-get obj 'Center))) ((= (strcase val) "AREA" (strcase txt))(setq end (vlax-get obj 'AREA))) ) ) ) (defun arcprops (obj txtlst) (foreach val lst (cond ((= (strcase val) "LAY") (setq lay (vlax-get obj 'layer))) ((= (strcase val) "LEN" (strcase txt))(setq len (vlax-get obj 'length))) ((= (strcase val) "RAD" (strcase txt))(setq rad (vla-get-radius obj))) ((= (strcase val) "CEN" (strcase txt))(setq cen (vlax-get obj 'Center))) ((= (strcase val) "START" (strcase txt))(setq area (vlax-get obj 'startpoint))) ((= (strcase val) "END" (strcase txt))(setq area (vlax-get obj 'endpoint))) ((= (strcase val) "AREA" (strcase txt))(setq end (vlax-get obj 'AREA))) ) ) ) ; starts here (setq ent (vlax-ename->vla-object (car (entsel "Pick Object ")))) ; do a check for object type then use defun ; pick an example below ; many examples copy to command line for testing mix and match ; (plprops ent '("LAY"))(princ lay) ; (plprops ent '("END"))(princ end) ; (plprops ent '("START"))(princ start) ; (plprops ent '("END" "START"))(princ end)(princ start) ; (plprops ent '("AREA" "LAY" "END" "START"))(princ area)(princ lay)(princ end)(princ start) ; (plprops ent '("START" "AREA" "LAY" "CW"))(princ start)(princ area)(princ cw) ; (plprops ent '("start" "END" "CORDS" "cw"))(princ start)(princ end)(princ coordsxy)(princ cw) ; (plprops ent '("CW"))(princ cw) ; (plprops ent '("AREA"))(princ area) ; (plprops ent '("CORDS"))(princ coordsxy) ; (lineprops ent "len"))(princ len) ; (lineprops ent '("len" "lay"))(princ len)(princ lay) ; (lineprops ent '("lay" "end" "start" "len"))(princ len)(princ lay)(princ start)(princ end) ; (circprops ent '("lay" "rad" "area" "cen"))(princ lay)(princ rad)(princ area)(princ cen) ; (circprops ent '("lay" "rad")) ; (arcprops ent '("lay" "rad")) So like PeterPan9720 you need to create a IF for each object type. Quote
