When I select the text, it is immediately set rotated how do I set it forever straight
When I select the text, it is immediately set rotated how do I set it forever straight? Thank you
There is 2 variables Angdir for Clockwise or Anti CW and Angbase is angle direction for zero, try 0 for both.
On autocad in Italian I do not find these variables. I probably need to find the correct translation, but I can't find it ...
I insert some pictures of the problem ...
Edited by Giovannino60
Other that the variables BIGAL mentioned default Text angle is the last text angle used in the drawing which isn't stored anywhere.
You could also be in a rotated view or UCS.
Try this copy to command line. It should be language independent.
(setvar 'angdir 0)
(setvar 'angbase 0)
