Change layer description of multiple layers based on layer name
I have layers like so:
AN_text
AN_level-proposed
WS_foundation
WS_wall
Is it possible to change the description of the AN_* layers to Annotation and the WS_* layers to Wall Structure using LISP?
;; RENAME LAYERS
(defun C:RL (/ layers layer nlay SS )
  (vlax-for layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (setq layer (vla-get-name layers))
    (cond
      ((wcmatch layer "AN_*")                                                       ;process layers that start with AN_
        (if (tblsearch "layer" (setq nlay (strcat "Annotation_" (substr layer 4)))) ;search layer table for Annotation_"layer name"
          (progn        ;if found move all entitys from old layer to new layer
            (setq SS (ssget "X" (list (cons 8 layer))))
            (command "_Chprop" SS "" "LA" nlay "")
            (command "_Purge" "LA" layer "N")
          (command "_-Rename" "LA" layer nlay)                                      ;if not found just rename old layer to new layer name
        (prompt (strcat "\n" Layer " -> " nlay))                                    ;output to command prompt layer update
      ((wcmatch layer "WS_*")                                                       ;same as above just looking for WS_
        (if (tblsearch "layer" (setq nlay (strcat "Wall Structure_" (substr layer 4))))
AN_text
AN_level-proposed
WS_foundation
WS_wall
These are layer names or descriptions strings ?
@mhupp, this is for renaming layers is it not? It's the description of the layer I was wanting to change based on the suffix of the layer name.
@Tharwat, these are layer names. The suffix is the main part. Helps break up each section of a building. WS is wall structure, WC is wall completion etc.
@tombu, thanks, I'll take a look at this and see.
Edited by 3dwannab
(defun c:Test ( / lyn)
  (vlax-for obj (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))
    (or (wcmatch (setq lyn (vla-get-name obj)) "*|*")
        (and (wcmatch lyn "AN_*,WS_*")
             (vla-put-Description obj (if (wcmatch lyn "AN_*") "Annotation" "Wall Structure"))
  ) (vl-load-com)
  • Like 2
  • Thanks 1
Thanks @Tharwat, What is the meaning of the wcmatch with the "*|*" ?
Ended up with this which doesn't change any that don't have a description:
(defun c:Test (/ obj layName)
    (setq layName (vla-get-name obj))
    (if (wcmatch (vla-get-Description obj) "")
        (if (wcmatch layName "AN_*") (vla-put-Description obj (strcat "Annotation Layer - " layName)))
        (if (wcmatch layName "CH_*") (vla-put-Description obj (strcat "Colour Hatch Layer - " layName)))
        (if (wcmatch layName "CL_*") (vla-put-Description obj (strcat "Ceiling Layer - " layName)))
        (if (wcmatch layName "DA_*") (vla-put-Description obj (strcat "Disablity Layer - " layName)))
        (if (wcmatch layName "DR_*") (vla-put-Description obj (strcat "Drainage Layer - " layName)))
        (if (wcmatch layName "EL_*") (vla-put-Description obj (strcat "Elevation Layer - " layName)))
        (if (wcmatch layName "FC_*") (vla-put-Description obj (strcat "Floor Completion Layer - " layName)))
        (if (wcmatch layName "FD_*") (vla-put-Description obj (strcat "Fire Denotation Layer - " layName)))
        (if (wcmatch layName "FS_*") (vla-put-Description obj (strcat "Floor Structure Layer - " layName)))
        (if (wcmatch layName "GN_*") (vla-put-Description obj (strcat "General Layer - " layName)))
        (if (wcmatch layName "RC_*") (vla-put-Description obj (strcat "Roof Completion Layer - " layName)))
        (if (wcmatch layName "RS_*") (vla-put-Description obj (strcat "Roof Structure Layer - " layName)))
        (if (wcmatch layName "SF_*") (vla-put-Description obj (strcat "Structural Frame Layer - " layName)))
        (if (wcmatch layName "ST_*") (vla-put-Description obj (strcat "Site Layer - " layName)))
        (if (wcmatch layName "TS_*") (vla-put-Description obj (strcat "Topographical Survey Layer - " layName)))
        (if (wcmatch layName "VT_*") (vla-put-Description obj (strcat "Vertical Transport Layer - " layName)))
        (if (wcmatch layName "WC_*") (vla-put-Description obj (strcat "Wall Completion Layer - " layName)))
        (if (wcmatch layName "WS_*") (vla-put-Description obj (strcat "Wall Structure Layer - " layName)))
(vl-load-com)
(c:Test)
Edited by 3dwannab
That's to pass over external references' layers.
Why are you asking for something and you are doing something else ?
Anyway, just build the list as I did in the following program to make it working professionally.
(defun c:Test ( / lst lyn )
  (setq lst '(("AN_" "Annotation Layer - ")
              ("CH_" "Colour Hatch Layer - ")
        (and (setq fnd (assoc (substr lyn 1 3) lst))
             (vla-put-Description obj (strcat (cadr fnd) lyn))
  ) (vl-load-com)
Edited by Tharwat
typo
  • Thanks 1
Thanks for that. That is just a minor tweak to what I had asked as some descriptions had already been set.
Its okay, no worries.
Beaten again by the questions and answers, below is taking MHUPPs idea and adding the layers as a list:
;; RENAME LAYERS
(defun C:RL (/ layers layer nlay SS acount RenameNames)
  (setq RenameNames (list '("AN_" "Annotation_")
                          '( "WS_" "Wall Structure_")
    (setq acount 0)
    (while ( < acount (length RenameNames))
      (setq searchterm (strcat (car (nth acount RenameNames)) "*"))
      (if (wcmatch layer searchterm)
          (if (tblsearch "layer" (setq nlay (strcat (cdr (nth acount RenameNames)) (substr layer 4) )))
            ) ;end progn
          ) ; end if
          ) ; end progn
        ) ; end if
        (setq acount (+ acount 1))
    ) ; end while
  ) ; end vlax-for
