Helli everyone,
I'm using this code to move all object to a specific point in layout and then exporting layout to dwg
(command "Move" "ALL" "" p1 p2)
(command "zoom" "e")
  (setq
    layoutname
     (strcat (getvar "dwgprefix")
	     "test"
	     ".dwg"
(command "exportlayout" layoutname)
it works fine but the exported file is not zoom extents after opening it. drawing always show  0.0 on opening.
Can someone tell me what the problem is ?
You may need a (command "Pspace") to ensure not in model space. You can get extmin extmax of a layout as window select then move extmin to 0,0 for consistency I do this setting all layouts in one go.
I always use ExportLayout on "Pspace" mode,
As for  the second recommendation, I intent to use ExportLayout at the moved location where it's not 0.0. When extmin is on 0.0, everything is okay and the problem appears when that exmin is not 0.0.
I use a lisp to plot and use window not layout option, unless something screwy by user works every time.
