LISP Routine to set COGO Point Label Style
I'm looking for a LISP Routine that I can use to set a COGO point's Label Style to a specific style by simply clicking on it instead of choosing it from the drop down in the properties menu. Any help would be appreciated, thank you!
Yep have that plus other stuff like rotate point. Yes for CIV3D cogo point.
Also have a set surface style as a toolbar rather than using toolspace. Wrong one redid icons but gives you an idea. The black square is off.
Civ3d Change point label style.lsp CIV3D point edit desc.lsp CIV3D Rotate point.lsp CIV3D create point.lsp CIV3D change point style.lsp Civ3d Change text style in labels.lsp CIV3D pt ht.lsp
  • Thanks 1
