pizarro Posted September 13, 2022 Share Posted September 13, 2022 Delete a duplicate 3D solids, its posible whit a Lisp ? Can you help me please. Quote Link to comment Share on other sites More sharing options...
mhupp Posted September 13, 2022 Share Posted September 13, 2022 (edited) Union command if they are in the same place. Edited September 13, 2022 by mhupp Quote Link to comment Share on other sites More sharing options...
pizarro Posted September 15, 2022 Author Share Posted September 15, 2022 When there aren't many elements, it's fine, but when you have a large number of overlapping elements and you don't know what they are, the situation is complicated. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 15, 2022 Share Posted September 15, 2022 I'm not sure, but Overkill might do it? 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted September 15, 2022 Share Posted September 15, 2022 (edited) 6 hours ago, Dadgad said: I'm not sure, but Overkill might do it? Unfortunately I think overkill only works on 2D objects. I think you would have to make a selection set of all solids compare them to each other by volume and geo center point if their is a match delete one --edit Could have false positive. so adding other tests would be better. Edited September 15, 2022 by mhupp Quote Link to comment Share on other sites More sharing options...
ronjonp Posted September 15, 2022 Share Posted September 15, 2022 (edited) 1 hour ago, mhupp said: Unfortunately I think overkill only works on 2D objects. I think you would have to make a selection set of all solids compare them to each other by volume and geo center point if their is a match delete one --edit Could have false positive. so adding other tests would be better. Agree ... here is a quick one. Definitely test it as it can be fooled by solids with 'equal' volume at different locations. Changed algorithm to be more reliable albeit slower. (defun c:foo (/ a b o r s) (cond ((setq s (ssget "_X" '((0 . "3DSOLID")))) (foreach e (mapcar 'cadr (ssnamex s)) (setq r (cons (list (vla-get-volume (setq o (vlax-ename->vla-object e))) (vlax-get o 'centroid) e) r ) ) ) (setq r (vl-sort r '(lambda (r j) (< (car r) (car j))))) (while (setq a (car r)) (setq r (cdr r)) ;; Slower but more reliable (setq b (vl-remove-if-not '(lambda (x) (and (equal (car a) (car x) 1e-4) (equal (cadr a) (cadr x) 1e-4))) r ) ) (foreach x b (entdel (last x)) (setq r (vl-remove x r))) ;;; (while (and (setq b (car r)) (equal (car a) (car b) 1e-4) (equal (cadr a) (cadr b) 1e-4)) ;;; (entdel (last b)) ;;; (setq r (cdr r)) ;;; ) ) ) ) (princ) ) Edited September 15, 2022 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
rax Posted October 19, 2022 Share Posted October 19, 2022 On 9/15/2022 at 7:47 PM, ronjonp said: Agree ... here is a quick one. Definitely test it as it can be fooled by solids with 'equal' volume at different locations. Changed algorithm to be more reliable albeit slower. (defun c:foo (/ a b o r s) (cond ((setq s (ssget "_X" '((0 . "3DSOLID")))) (foreach e (mapcar 'cadr (ssnamex s)) (setq r (cons (list (vla-get-volume (setq o (vlax-ename->vla-object e))) (vlax-get o 'centroid) e) r ) ) ) (setq r (vl-sort r '(lambda (r j) (< (car r) (car j))))) (while (setq a (car r)) (setq r (cdr r)) ;; Slower but more reliable (setq b (vl-remove-if-not '(lambda (x) (and (equal (car a) (car x) 1e-4) (equal (cadr a) (cadr x) 1e-4))) r ) ) (foreach x b (entdel (last x)) (setq r (vl-remove x r))) ;;; (while (and (setq b (car r)) (equal (car a) (car b) 1e-4) (equal (cadr a) (cadr b) 1e-4)) ;;; (entdel (last b)) ;;; (setq r (cdr r)) ;;; ) ) ) ) (princ) ) How can i move the duplicate object in to new layer instead of deleting?? Quote Link to comment Share on other sites More sharing options...
rax Posted October 19, 2022 Share Posted October 19, 2022 Can you bit adjust the lisp to delete duplicate object into a new layer instead of deleting?? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 19, 2022 Share Posted October 19, 2022 10 minutes ago, rax said: Can you bit adjust the lisp to delete duplicate object into a new layer instead of deleting?? ;; Change this (foreach x b (entdel (last x)) (setq r (vl-remove x r))) ;; to this (foreach x b (append (entget (last x)) '((8 . "Duplicate"))) (setq r (vl-remove x r))) 2 Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 21, 2022 Share Posted October 21, 2022 Ja, eto imam neke rutine vezane za sam overkill element... Mozda Vam moze koristiti, mada nisam u potpunosti siguran... OVERKILL.ZIP Quote Link to comment Share on other sites More sharing options...
