Lisp for delete duplicate 3D Solids
pizarro
When there aren't many elements, it's fine, but when you have a large number of overlapping elements and you don't know what they are, the situation is complicated.
6 hours ago, Dadgad said:
I'm not sure, but Overkill might do it?   :beard:
Unfortunately I think overkill only works on 2D objects.
I think you would have to
  • make  a selection set of all solids
  • compare them to each other by volume and geo center point
  • if their is a match delete one
--edit
Could have false positive. so adding other tests would be better.
Edited by mhupp
--edit
Agree ... here is a quick one. Definitely test it as it can be fooled by solids with 'equal' volume at different locations.  Changed algorithm to be more reliable albeit slower.
(defun c:foo (/ a b o r s)
  (cond	((setq s (ssget "_X" '((0 . "3DSOLID"))))
	 (foreach e (mapcar 'cadr (ssnamex s))
	   (setq r
		  (cons	(list (vla-get-volume (setq o (vlax-ename->vla-object e))) (vlax-get o 'centroid) e)
			r
	 (setq r (vl-sort r '(lambda (r j) (< (car r) (car j)))))
	 (while	(setq a (car r))
	   (setq r (cdr r))
	   ;; Slower but more reliable
	   (setq b (vl-remove-if-not
		     '(lambda (x) (and (equal (car a) (car x) 1e-4) (equal (cadr a) (cadr x) 1e-4)))
		     r
	   (foreach x b (entdel (last x)) (setq r (vl-remove x r)))
;;;       (while (and (setq b (car r)) (equal (car a) (car b) 1e-4) (equal (cadr a) (cadr b) 1e-4))
;;;	 (entdel (last b))
;;;	 (setq r (cdr r))
Edited by ronjonp
  • 1 month later...
	   (setq r
			r
	   (setq r (cdr r))
		     r
How can i move the duplicate object in to new layer instead of deleting??
10 minutes ago, rax said:
Can you bit adjust the lisp to delete duplicate object into a new layer instead of deleting??
;; Change this
;; to this
(foreach x b (append (entget (last x)) '((8 . "Duplicate"))) (setq r (vl-remove x r)))
  • Like 2
