jim78b Posted September 13, 2022 Share Posted September 13, 2022 ^C^C_select \_change _p; _p _c byblock;;_block \ _O;_C; i don't know wht autocad don't does not recognize intermediate commands like in block... Specific insertion point [Annotatio mOde] i want define the mOde so to retain the block in my drawing, but with my macro don' work Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 13, 2022 Author Share Posted September 13, 2022 after i create block autocad delete it! Quote Link to comment Share on other sites More sharing options...
mhupp Posted September 13, 2022 Share Posted September 13, 2022 The entity's are gone but now its in your block library. you need to insert the block back into the drawing. Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 14, 2022 Author Share Posted September 14, 2022 HELLO , but why autocad delete it if i use this as macro? i want automatize and retain in the drawing the block Quote Link to comment Share on other sites More sharing options...
mhupp Posted September 14, 2022 Share Posted September 14, 2022 See if this works. ^C^C_select \_change _p; _p _c byblock;;_block \ _O;_R; 1 Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 14, 2022 Author Share Posted September 14, 2022 not work, after block creation, autocad remove it! Quote Link to comment Share on other sites More sharing options...
