wef Posted September 12, 2022 Posted September 12, 2022 Hello, I was getting a drawing that I have to modify. The problem is, that in this drawing are several block references with the name. I.e. I have about 100 block references calling "WcLux" . Is there a possibility to make the name of the block reference unique with a script: WcLux_1, WcLux2, ... WcLux100 Thx Frank Quote
mhupp Posted September 12, 2022 Posted September 12, 2022 (edited) This should work. if their are attributes might have to use burst instead of explode. --edit Also doesn't check for bylayer or byblock colors so things might change after explode. ;;----------------------------------------------------------------------------;; ;; make unique block names (defun C:UB (/ blk blkname ss en name ss1 ptslst LL UR MPT) (vl-load-com) (setq ss1 (ssadd) blk (car (entsel "\nSelect Block")) ;no error testing so make sure you select a block blkname (cdr (assoc 2 (entget blk))) i 1 ) (if (and (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 blkname) '(410 . "Model")))) (> (sslength ss) 1)) (foreach blk (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (setq LastEnt (entlast)) (setq LL nil UR nil MPT nil ptslst nil) (command "_.Explode" blk) (if (setq en (entnext LastEnt)) (while en (ssadd en SS1) (setq obj (vlax-ename->vla-object en)) (vla-getboundingbox obj 'minpt 'maxpt) (setq ptslst (cons (vlax-safearray->list minpt) ptslst) ptslst (cons (vlax-safearray->list maxpt) ptslst) ) (setq en (entnext en)) ) ) (setq LL (apply 'mapcar (cons 'min ptslst)) UR (apply 'mapcar (cons 'max ptslst)) MPT (mapcar '/ (mapcar '+ LL UR) '(2 2 2)) ) (while (tblsearch "BLOCK" (strcat blkname "-" (itoa i))) (setq i (1+ i)) ) (setq name (strcat blkname "-" (itoa i))) (vl-cmdf "_.Block" name "_non" MPT SS1 "") (vl-cmdf "_.Insert" name "_non" MPT 1 1 0) ) ) ) Edited September 12, 2022 by mhupp Quote
ronjonp Posted September 12, 2022 Posted September 12, 2022 (edited) If you don't care what the name is this would make them unique: (defun c:ub (/ b s) (if (and (setq b (car (entsel "\nSelect Block"))) (= "INSERT" (cdr (assoc 0 (entget b)))) (setq s (ssget "_X" (list '(0 . "INSERT") (assoc 2 (entget b))))) ) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (vla-converttoanonymousblock (vlax-ename->vla-object e)) ) ) (princ) ) (vl-load-com) Edited September 12, 2022 by ronjonp 1 Quote
Steven P Posted September 13, 2022 Posted September 13, 2022 I wonder if this can be modified: https://autocadtips1.com/2011/05/03/autolisp-copy-block-with-new-name/ It copies a selected block, lets you choose a new name and insert that as a new block. Perhaps use RonJonPs start, select the block to rename, ssget all the blocks of that name, then a loop and passing insertion point, new name and block from selection set to this, copy and rename a lot of blocks then delete everything in the original selection set Quote
