add to block from leemac bugs
jim78b
;;----------------------=={ Add Objects to Block }==--------------------;;
;;  This program enables the user to add a selection of objects to the  ;;
;;  definition of a selected block.                                     ;;
;;  Upon issuing the command syntax 'addtoblock' at the AutoCAD         ;;
;;  command line, the program prompts the user for a selection of       ;;
;;  objects residing on unlocked layers to be added to a chosen block   ;;
;;  definition.                                                         ;;
;;  Following a valid selection, the program prompts the user to select ;;
;;  a reference of a block whose definition is to be modified to        ;;
;;  incorporate all objects in the selection.                           ;;
;;  At this prompt, the program will permit selection of any standard   ;;
;;  (non-dynamic) uniformly scaled block reference which is not         ;;
;;  referenced within the selection (as a block reference cannot be     ;;
;;  added to its own definition).                                       ;;
;;  Every object in the selection will then be transformed relative to  ;;
;;  the position, scale, rotation, and orientation of the selected      ;;
;;  block reference, before being copied to the definition of the       ;;
;;  block and removed from the drawing.                                 ;;
;;  Author:  Lee Mac, Copyright © 2011  -  www.lee-mac.com              ;;
;;  Version 1.1    -    2011-05-31                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.2    -    2020-11-15                                      ;;
;;  - Program completely rewritten to incorporate a check for           ;;
;;    references of the target block within the selected objects.       ;;
(defun c:addtoblock ( / *error* bln bnl btr def ent enx idx lst sel tmp )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
    (LM:startundo (LM:acdoc))
    (cond
        (   (not (setq sel (LM:ssget "\nSelect objects to add to block: " '("_:L")))))
        (   (progn
                (repeat (setq idx (sslength sel))
                    (setq idx (1- idx)
                          ent (ssname sel idx)
                          enx (entget ent)
                          lst (cons (vlax-ename->vla-object ent) lst)
                    (if (and (= "INSERT" (cdr (assoc 0 enx)))
                             (not (member (setq bln (strcase (cdr (assoc 2 enx)))) bnl))
                        (setq bnl (cons bln bnl))
                (while (setq def (tblnext "block" (not def)))
                    (setq ent (tblobjname "block" (cdr (assoc 2 def))))
                    (while (setq ent (entnext ent))
                        (if (= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
                            (setq tmp (cons (strcase (cdr (assoc 2 enx))) tmp))
                    (if tmp
                        (setq btr (cons (cons (strcase (cdr (assoc 2 def))) tmp) btr)
                              tmp nil
                (while
                    (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect block: ")))
                        (cond
                            (   (= 7 (getvar 'errno))
                                (princ "\nMissed, try again.")
                            (   (null ent)
                                nil
                            (   (/= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
                                (princ "\nThe selected object is not a block.")
                            (   (not
                                    (and
                                        (equal (abs (cdr (assoc 41 enx))) (abs (cdr (assoc 42 enx))) 1e-8)
                                        (equal (abs (cdr (assoc 41 enx))) (abs (cdr (assoc 43 enx))) 1e-8)
                                (princ "\nThis program is not currently compatible with non-uniformly scaled blocks - sorry.")
                            (   (= :vlax-true (vla-get-isdynamicblock (vlax-ename->vla-object ent)))
                                (princ "\nThis program is not currently compatible with dynamic blocks - sorry.")
                            (   (vl-some '(lambda ( bln ) (member bln bnl))
                                        (lambda ( / rtn )
                                            (foreach def btr
                                                (cond
                                                    (   (= bln (car def)))
                                                    (   (member (car def) rtn))
                                                    (   (addtoblock:referenced-p bln (cdr def) btr) (setq rtn (cons (car def) rtn)))
                                            (cons bln rtn)
                                (princ "\nThe selected block is referenced by a block in the selection.")
                ent
            (   (lambda ( mat )
                    (foreach obj lst (vla-transformby obj mat))
                    (vla-copyobjects (LM:acdoc)
                        (vlax-make-variant
                            (vlax-safearray-fill
                                (vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst))))
                                lst
                        (vla-item (vla-get-blocks (LM:acdoc)) (cdr (assoc 2 (entget ent))))
                    (foreach obj lst (vla-delete obj))
                    (vla-regen (LM:acdoc) acallviewports)
                (apply
                    (function
                        (lambda ( mat vec )
                            (vlax-tmatrix
                                (append
                                    (mapcar
                                        (function
                                            (lambda ( x v )
                                                (append x (list v))
                                        mat vec
                                   '((0.0 0.0 0.0 1.0))
                    (revrefgeom ent)
(defun addtoblock:referenced-p ( bln def lst )
    (or (member bln def)
        (vl-some '(lambda ( nst ) (addtoblock:referenced-p bln (cdr (assoc nst lst)) lst)) def)
;; RevRefGeom (gile)
;; The inverse of RefGeom
(defun revrefgeom ( ent / ang enx mat ocs )
          ang (cdr (assoc 050 enx))
          ocs (cdr (assoc 210 enx))
    (list
        (setq mat
            (mxm
                (list
                    (list (/ 1.0 (cdr (assoc 41 enx))) 0.0 0.0)
                    (list 0.0 (/ 1.0 (cdr (assoc 42 enx))) 0.0)
                    (list 0.0 0.0 (/ 1.0 (cdr (assoc 43 enx))))
                (mxm
                    (list
                        (list (cos ang)     (sin ang) 0.0)
                        (list (- (sin ang)) (cos ang) 0.0)
                       '(0.0 0.0 1.0)
                    (mapcar '(lambda ( v ) (trans v ocs 0 t))
                             (1.0 0.0 0.0)
                             (0.0 1.0 0.0)
                             (0.0 0.0 1.0)
        (mapcar '- (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx)))))
            (mxv mat (trans (cdr (assoc 10 enx)) ocs 0))
;; Matrix Transpose  -  Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Matrix x Matrix  -  Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: AddObjectsToBlock.lsp | Version 1.2 | \\U+00A9 Lee Mac "
        ((lambda ( y ) (if (= y (menucmd "m=$(edtime,0,yyyy)")) y (strcat y "-" (menucmd "m=$(edtime,0,yyyy)")))) "2011")
        " www.lee-mac.com ::"
        "\n:: Type \"addtoblock\" to Invoke ::"
;;                             End of File                              ;;
i have this code from leemac, the problem after adding an element from outside a block, sometimes if i want to select the block from this newly added element, i can't, it is not selectable.
Do you know that if you state or comment something subjective as word "bug", you are responsible for overcoming situation with knowledge and wisdom unique to your vision of composing harmonic and valuable system of functional algorithmic application (if your goal is in field of science based on computational technology)...
  • Funny 1
  • 1 month later...
