Steven P Posted September 13, 2022 Share Posted September 13, 2022 Sure if you look in the LISP there is a line (setq BlockName... or something like that, setq to set a variable, BlockName.... gives a clue what variable that is.... Then a simple internet search to find out how to enter a string into a L:ISP (quite easy).. (getstring ) This should work with a couple of other tweaks (defun c:chcol ( / MySS ) (setq MySS (ssget)) (command "chprop" MySS "" "C" "ByBlock" "") (setq BlockName (getstring "Enter Bloc Name: ") (c:blk MySS BlockName) ) ;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-create-block-insert-that-block/td-p/5431779 ;;(defun c:blk (/ selectionset insertionpoint number Blockname) (defun c:blk (selectionset MyBlock / insertionpoint number Blockname) ;; (if (and (setq selectionset (ssget "_:L")) (setq insertionpoint (getpoint "\n Specify Block Insertion Point :")) ;; ) (progn (setq number 1 Blockname MyBlock ) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat MyBlock (itoa (setq number (1+ number)))) ) ) (command "_.-Block" Blockname insertionpoint selectionset "") (command "_.-insert" Blockname insertionpoint "" "" "") ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 13, 2022 Author Share Posted September 13, 2022 Thanks very much for you is very simply write code ...i think never learn . Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 13, 2022 Author Share Posted September 13, 2022 give me syntax error! Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 13, 2022 Share Posted September 13, 2022 Ah yes I missed a ')' - updated the code above (often syntax error means I have forgotten a closing bracket ), and you just need to work through the code to find where it is) Learning LISP is quite easy - take some time to work out what this does and you'll get there Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 13, 2022 Author Share Posted September 13, 2022 sorry i don't want I do not want to bother you Quote Link to comment Share on other sites More sharing options...
jim78b Posted September 13, 2022 Author Share Posted September 13, 2022 sorry i tried again but give syntax error Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 13, 2022 Share Posted September 13, 2022 That's weird, it didn't update the code above, try this: (defun c:chcol ( / MySS ) (setq MySS (ssget)) (command "chprop" MySS "" "C" "ByBlock" "") (setq BlockName (getstring "Enter Block Name: ")) (c:blk MySS BlockName) ) ;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-create-block-insert-that-block/td-p/5431779 ;;(defun c:blk (/ selectionset insertionpoint number Blockname) (defun c:blk (selectionset MyBlock / insertionpoint number Blockname) ;; (if (and (setq selectionset (ssget "_:L")) (setq insertionpoint (getpoint "\n Specify Block Insertion Point :")) ;; ) ; end and (progn (setq number 1 Blockname MyBlock ) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat MyBlock (itoa (setq number (1+ number)))) ) ) (command "_.-Block" Blockname insertionpoint selectionset "") (command "_.-insert" Blockname insertionpoint "" "" "") ) ; end progn ; ) ; end if (princ) ) Quote Link to comment Share on other sites More sharing options...
