pietrow Posted September 8, 2022 Posted September 8, 2022 Hi, is there possibility to create lisp that will: - ask for two plines; - set elevation to 0 for both plines; - trim the shorter part (from the point of intersection) of each pline; - join them into one pline. Quote
mhupp Posted September 8, 2022 Posted September 8, 2022 (edited) upload a sample drawing what your looking for Edited September 8, 2022 by mhupp 1 Quote
lido Posted September 8, 2022 Posted September 8, 2022 Have you tried the FILLET command with radius 0 (zero)? 1 Quote
pietrow Posted September 9, 2022 Author Posted September 9, 2022 Command FILLET its enough, but only for plines at the same level. I'm going to try write a lisp with this command but with setting elevation at 0 before command. Thank you. Quote
BIGAL Posted September 9, 2022 Posted September 9, 2022 3d poly with same XY but different Z on matching end do not Meet. You have 2 choices flatten or push 1 end to the other end point. 1 Quote
Steven P Posted September 10, 2022 Posted September 10, 2022 There are LISPs out there that will find the intersection of 2 lines or polylines, I think also 3d lines. Can you do entmod the first point of one line, the last point of the other to be this intersection point and then do a polyline join for 3d polyline - I think all these parts are out there sopmewhere 1 Quote
