mugshot Posted September 5, 2022 Posted September 5, 2022 (edited) Hello gents/ladies its been long since i ask something, and i am thankful, it helps me a lot ever since. again, may i ask... is there a lisp that, sample file A... has tab name "LAME" ... and then when i go to file B, (some sort of like a hyperlink) and i link file A with a tab name "lame"....is that possible? not just the file but directly to the tab? and also if i rename the tab name "lame" from file A, it changes automatically to file B where i link the file A tab name "lame". thank you and God bless... Edited September 5, 2022 by mugshot Quote
BIGAL Posted September 6, 2022 Posted September 6, 2022 Not sure if OBDX will allow you to change a hyperlink. The other way is to write a script that opens the B dwg, changes it, then closes. If dwg is not massive then it will take a few seconds. Quote
mugshot Posted September 6, 2022 Author Posted September 6, 2022 BIGAL... but is it possible? its like inter-linking 2 files ...? Quote
BIGAL Posted September 7, 2022 Posted September 7, 2022 Is it possible more than likely just have to work how to do it, if you write down all the steps to do manually then that becomes your script. Just copy paste the text screen between the 2 dwgs then can have a look. Quote
tombu Posted September 7, 2022 Posted September 7, 2022 On 9/5/2022 at 12:19 AM, mugshot said: Hello gents/ladies its been long since i ask something, and i am thankful, it helps me a lot ever since. again, may i ask... is there a lisp that, sample file A... has tab name "LAME" ... and then when i go to file B, (some sort of like a hyperlink) and i link file A with a tab name "lame"....is that possible? not just the file but directly to the tab? and also if i rename the tab name "lame" from file A, it changes automatically to file B where i link the file A tab name "lame". thank you and God bless... You can do that and more with Sheet Sets. SHEETS HAPPEN! Introduction to the Sheet Set Manager https://forums.autodesk.com/autodesk/attachments/autodesk/66/257215/1/Sheets_Happen.pdf 1 Quote
