aridzv Posted August 31, 2022 Share Posted August 31, 2022 (edited) Hi. I need to select multiple polylines and break each one of them at their vertices. I use this line of code to get just the polylines from a selection set and put them in a list: (setq ss (ssget '((0 . "*POLYLINE")))) and I found this lisp that break a polyline at its vertices in this topic: ;;; Break pline @ vertices LPS 2010-04-01 (defun c:test (/ idx obj endparam ptlst) (vl-load-com) (setq temperr *error*) (setq *error* errortrap) (setq obj (vlax-ename->vla-object (car (setq ent (entsel "\nSelect polyline: ")))) ) (if ; test if polyline (/= (vlax-get-property obj 'ObjectName) "AcDbPolyline") (princ "\nSelected entity is not a polyline") ) (setq ptlst (list (vlax-curve-getStartPoint obj)) idx 1) (if (zerop (vlax-get obj 'Closed)) (setq endparam (vlax-curve-getParamAtPoint obj (vlax-curve-getEndPoint obj)));if open param at end point (setq endparam (cdr (assoc 90 (entget (vlax-vla-object->ename obj)))));if closed # vertices ) (while (<= idx endparam) (setq ptlst (cons (vlax-curve-getPointAtParam obj idx) ptlst) idx (1+ idx) ) ) (mapcar (function (lambda (x) (vl-cmdf "break" ent "f" x "@"))) ptlst) (princ) );defun (defun errortrap (msg) (if (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n<< Error: " msg " >>"))) (setq *error* temperr) (princ) ) I need help putting this list into a loop that will go through each polyline in the list and break it at its vertices using the Break pline @ vertices LPS from the topic in the link I have attached above. thanks, aridzv * I need to keep those segments as polylines - that is why I don't explode them... Edited August 31, 2022 by aridzv Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 31, 2022 Share Posted August 31, 2022 (edited) Give this a try: (defun c:foo (/ a b el h pts s) ;; RJP » 2022-08-31 ;; Explode LWPOLYLINES and keep segment widths (if (setq s (ssget ":L" '((0 . "LWPOLYLINE")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq h (assoc 10 (setq el (entget e '("*"))))) (setq h (vl-remove (assoc 70 el) (reverse (cdr (member h (reverse el)))))) (setq pts (vl-remove-if-not '(lambda (x) (member (car x) '(10 40 41 42 91))) el)) (if (vlax-curve-isclosed e) (setq pts (append pts (mapcar '(lambda (r j) r) pts '(0 0 0 0 0)))) ) (while (> (length pts) 5) (entmakex (append h (mapcar '(lambda (r j) r) pts '(0 0 0 0 0 0 0 0 0 0)) (list (assoc 210 el))) ) (setq pts (cdddr pts)) (setq pts (cddr pts)) ) (entdel e) ) ) (princ) ) Edited August 31, 2022 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
aridzv Posted August 31, 2022 Author Share Posted August 31, 2022 @ronjonp PERFECT - Thanks!! aridzv Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 31, 2022 Share Posted August 31, 2022 1 minute ago, aridzv said: @ronjonp PERFECT - Thanks!! aridzv 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted August 31, 2022 Share Posted August 31, 2022 (edited) Just beaten to it in the time it took me to log in.... A slightly difffernt method here - there are many ay to do many things. I was going to suggest making 2 routines, keeping one for breaking a single polyline and another to do a loop hrough the selection set (sometimes this is good that you can use the main code for many things) The loop: (defun c:test ( / ss acount ) (setq acount 0) ;; a counter (setq ss (ssget '((0 . "*POLYLINE")))) ;;select poylines (while (< acount (sslength ss)) (test (ssname ss acount)) ;;call functon 'test' (setq acount (+ acount 1)) ) ;; end while ) and then modifyng your c:test above, ;;; Break pline @ vertices LPS 2010-04-01 ;;;(defun c:test (/ idx obj endparam ptlst) (defun test ( myent / idx obj endparam ptlst) (vl-load-com) (setq temperr *error*) (setq *error* errortrap) ;;;;(setq obj (vlax-ename->vla-object (car (setq ent (entsel "\nSelect polyline: ")))) ) (setq obj (vlax-ename->vla-object (setq ent myent)) ) (if (/= (vlax-get-property obj 'ObjectName) "AcDbPolyline") (princ "\nSelected entity is not a polyline") ) ;;end if (setq ptlst (list (vlax-curve-getStartPoint obj)) idx 1 ) (if (zerop (vlax-get obj 'Closed)) (setq endparam (vlax-curve-getParamAtPoint obj (vlax-curve-getEndPoint obj)));if open param at end point (setq endparam (cdr (assoc 90 (entget (vlax-vla-object->ename obj)))));if closed # vertices ) ;;end if (while (<= idx endparam) (setq ptlst (cons (vlax-curve-getPointAtParam obj idx) ptlst) idx (1+ idx) ) ) ;;end while ;;;; (mapcar (function (lambda (x) (vl-cmdf "break" ent "f" x "@"))) ptlst) (mapcar (function (lambda (x) (vl-cmdf "break" (vlax-curve-getStartPoint obj) "f" x "@"))) ptlst) ) ;; end defun (defun errortrap (msg) (if (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n<< Error: " msg " >>")) ) ;;end if (setq *error* temperr) (princ) ) or something like this - evening here so CAD is off, didn't test this Edited September 1, 2022 by Steven P Corrected typo and corrected code 1 Quote Link to comment Share on other sites More sharing options...
aridzv Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) @Steven P Thanks for the reply! I've run your code in one lsp file like this: (defun c:test ( / ss acount ) (setq acount 0) ;; a counter (setq ss (ssget '((0 . "*POLYLINE")))) ;;select poylines (while (< acount (sslength ss)) (test (ssname ss acount)) ;;call functon 'test' (setq acount (+ acount 1)) ) ;; end while ) ;;; Break pline @ vertices LPS 2010-04-01 ;;;(defun c:test (/ idx obj endparam ptlst) (defun test ( myent / idx obj endparam ptlst) (vl-load-com) (setq temperr *error*) (setq *error* errortrap) ;;;;(setq obj (vlax-ename->vla-object (car (setq ent (entsel "\nSelect polyline: ")))) ) (setq obj (vlax-ename->vla-object (car (setq ent myent))) ) (if ; test if polyline (/= (vlax-get-property obj 'ObjectName) "AcDbPolyline") (princ "\nSelected entity is not a polyline") ) (setq ptlst (list (vlax-curve-getStartPoint obj)) idx 1) (if (zerop (vlax-get obj 'Closed)) (setq endparam (vlax-curve-getParamAtPoint obj (vlax-curve-getEndPoint obj)));if open param at end point (setq endparam (cdr (assoc 90 (entget (vlax-vla-object->ename obj)))));if closed # vertices ) (while (<= idx endparam) (setq ptlst (cons (vlax-curve-getPointAtParam obj idx) ptlst) idx (1+ idx) ) ) (mapcar (function (lambda (x) (vl-cmdf "break" ent "f" x "@"))) ptlst) (princ) );defun (defun errortrap (msg) (if (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n<< Error: " msg " >>"))) (setq *error* temperr) (princ) ) *EDIT: the code in c:test had a small typing error - "(setw acount 0)", I fixed it to "(setq acount 0)".... I get this error: ; ----- LISP : Call Stack ----- ; [0]...C:TEST ; [1].....TEST <<-- ; ; ----- Error around expression ----- ; (AL-ENAME2OBJ ENAME) ; in file : ; C:\Temp\Break_pline_By_vertices4.lsp I can't find why, and my lisp writing skills are not at a sufficient level to solve the problem.... 8 hours ago, Steven P said: .... evening here so CAD is off, didn't test this no worries,tomorrow is a new day and Thanks anyway for the answer!! aridzv Edited September 1, 2022 by aridzv Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 1, 2022 Share Posted September 1, 2022 (edited) 10 hours ago, aridzv said: @Steven P Thanks for the reply! I've run your code in one lsp file like this: *EDIT: the code in c:test had a small typing error - "(setw acount 0)", I fixed it to "(setq acount 0)".... I get this error: ; ----- LISP : Call Stack ----- ; [0]...C:TEST ; [1].....TEST <<-- ; ; ----- Error around expression ----- ; (AL-ENAME2OBJ ENAME) ; in file : ; C:\Temp\Break_pline_By_vertices4.lsp I can't find why, and my lisp writing skills are not at a sufficient level to solve the problem.... no worries,tomorrow is a new day and Thanks anyway for the answer!! aridzv Suspect there might be a couple of errors in there - was writing it on the laptop watching the TV and didn't have CAD running to check - I'll check and update the code above for you ....edited code above, couple of small errors, Edited September 1, 2022 by Steven P 1 Quote Link to comment Share on other sites More sharing options...
