NicholasCAD Posted August 31, 2022 Posted August 31, 2022 (edited) (Hopefully this Question has not been asked. The Search gave no Results.) For Context: I have created a Program that generates a complex Component (Block, Wiring, Text) onto a Sheet. The Program uses .LSP and .DCL for ease of Use for our Operators. The Prompt has Options to configure the Component to any Options we need. Inquiry: I need to update the Program to include Wire Numbers and Wire Number Copies. (I will be trying to use "WD_PUTWNXY" Command for New Wire Networks, although I have yet to do so.) For Wire Number Copies, I was hoping to use either the "AECOPYWIRENO" or "WD_COPY_WN" Commands. The Problem with these Commands is that they do not allow for Coordinate Placement. When running either Command, the Command Line is requesting to select a Wire as an Entity. What I would like, is an example of a LISP that completes this Task using a Coordinate System to select and place the Wire Number Copies. Any Advice would be much appreciated! Edited August 31, 2022 by NicholasCAD Quote
BIGAL Posted September 1, 2022 Posted September 1, 2022 Have you looked at SNAP and GRID when picking points. Quote
NicholasCAD Posted September 1, 2022 Author Posted September 1, 2022 I am not sure what you mean. The copywn Commands ask for an Entity. It would be alot easier to be able to specify a Pick Point. When using these Commands manually, the Cursor acts as the Locator for where the Copy will be placed. However, while using the Commands in LISP, I have not been able to use Coordinates. Quote
BIGAL Posted September 2, 2022 Posted September 2, 2022 Did you look at how SNAP works set a value you will see mouse jump as you move, say 10. Set Grid to same value. Quote
NicholasCAD Posted September 6, 2022 Author Posted September 6, 2022 BIGAL, are you Sea-Haven on Autodesk Forums? You have the same Profile Pic. If so, refer to my post here. Essentially this has to do with a Program that Auto Generates a Schematic Sheet in a Drawing Project. This does not use Manual User Input to select the Wire that needs a Copy Wire Number Block. Quote
