leonucadomi Posted August 25, 2022 Share Posted August 25, 2022 (edited) hello : I use this routine to create folder with the current file path Edited August 26, 2022 by leonucadomi Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 25, 2022 Share Posted August 25, 2022 (edited) 5 minutes ago, leonucadomi said: hello : I use this routine to create folder with the current file path but I don't know how I can create a folder inside that folder can anybody help me? (defun C:TEST (/ dwgpre) (setq dwgpre (strcat (getvar "dwgprefix") "\RV 0")) (if (= (vl-file-directory-p dwgpre) nil) (vl-mkdir dwgpre) ) );DEFUN You need a double backslash \\RV 0 and you don't need to check if it exists: (defun c:test nil (vl-mkdir (strcat (getvar "dwgprefix") "\\RV 0"))) Here is a quick example to make nested folders: (defun c:test (/ pre) (setq pre (getvar 'dwgprefix)) (foreach d '("\\RV 0" "\\RV 1" "\\RV 2") (vl-mkdir (setq pre (strcat pre d)))) ) Edited August 25, 2022 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted August 25, 2022 Author Share Posted August 25, 2022 I WANT TO CREATE A FOLDER CALLED "RV 0" AND WITHIN TWO FOLDERS HELP PLEASE Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted August 25, 2022 Author Share Posted August 25, 2022 ONE CALLED DWG AND ANOTHER PDF Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 25, 2022 Share Posted August 25, 2022 49 minutes ago, leonucadomi said: ONE CALLED DWG AND ANOTHER PDF (defun c:test (/ pre) (vl-mkdir (setq pre (strcat (getvar 'dwgprefix) "\\RV 0"))) (foreach d '("\\DWG" "\\PDF") (vl-mkdir (strcat pre d))) ) Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted August 25, 2022 Author Share Posted August 25, 2022 excellent it has been very helpful thank you Quote Link to comment Share on other sites More sharing options...
