Hi everyone! I have 2 smalls codes that does exactly the same thing but for different text heights. We select all elements in a drawing, it finds all text elements with a certain height and it deletes it! The c:TE code works perfectly , the text height is 2.4. I'm having a problem with the c:ES one, the height is set to 1.5688 but it's not detecting those specific text elements? Is it because it's a roundup height number? If yes, how can I know the exact height of this specific text? You can have a look at the attached drawing for better understanding!
Thank you very much!
Have a good day!
(defun c:ES (/ ss)
if (setq ss (ssget "_:L" '((0 . "TEXT") (40 . 1.5688))))
(command "_.erase" ss"")
(defun c:TE (/ ss)
if (setq ss (ssget "_:L" '((0 . "TEXT") (40 . 2.4))))
TEXTHEIGHTSELECTION.dwg
It worked OK for just testing it,  though I think it will fail if the text height isn't exactly what it is looking for - you'll need a fuzz factor
Someone will be able to help out with that, not something I do much
  • Agree 1
Thanks Steven P! I think of an other option, how would I code, select text if it contain the word "SEAM"?
Use getss just like you are, but create a loop (use sslength to get the size) and search the contents of the text for the string "SEAM".  You can use wcmatch or vl-string-search to see if the string is contained.  Likewise, you can use the same strategy - looping through the selection set - to check the text height and locate ones within a range (the fuzz factor mentioned earlier).
(if (setq ss (ssget "_:L" '((0 . "TEXT") (1 . "SEAM"))))) ;TEXT THAT IS ONLY SEAM       "STEM"
(if (setq ss (ssget "_:L" '((0 . "TEXT") (1 . "*SEAM*"))))) ;TEXT THAT HAS SEAM IN IT	"123STEM123"
(if (setq ss (ssget "_:L" '((0 . "TEXT") (1 . "SEAM*"))))) ;TEXT THAT STARTS WITH SEAM	"SEAM123"
(if (setq ss (ssget "_:L" '((0 . "TEXT") (1 . "*SEAM"))))) ;TEXT THAT ENDS WITH SEAM	"123SEAM"
Edited by mhupp
Have a good day!
(defun c:ES (/ ss)
(defun c:TE (/ ss)
Not sure how that code is working since it's missing parenthesis 🤔.
Give this fuzzy filter a try:
(defun c:es (/ ss)
		      '((0 . "TEXT")
			;; Filter text height between 1.568 and 1.569
			(-4 . "<AND")
			(-4 . ">=")
			(40 . 1.568)
			(-4 . "<=")
			(40 . 1.569)
			(-4 . "AND>")
    (command "_.erase" ss "")
Thanks guys! mhupp, this solution is perfect for me, meaning it's the simpliest one!! Is there a document somewhere explaining all these details? For example, (0. "TEXT") 0=? (1. "SEAM") 1=? etc... 2,3,4?
https://www.afralisp.net/reference/dxf-group-codes.php
http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-62E5383D-8A14-47B4-BFC4-35824CAE8363.htm,topicNumber=d30e678406
Use this on entity's in your drawing to see their codes.
;; Dump all DXF Group Data
(defun C:DumpIt (/ ent)
  (while (setq ent (car (entsel "\nSelect Entity to Dump")))
    (mapcar 'print (entget ent '( "*")))
  (textscr)
Will output something like this
: DUMPIT
(-1 . <Entity name: 58c26d50>)
(0 . "TEXT")
(5 . "27081")
(330 . <Entity name: 76dcfc50>)
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "Laser_Engrave")
(370 . -1)
(100 . "AcDbText")
(10 36.4035806973546 -37.4216521303144 0.0)
(40 . 0.125)
(1 . "SEAM IS MY NAMEO")
(50 . 0.0)
(41 . 1.0)
(51 . 0.0)
(7 . "Standard")
(71 . 0)
(72 . 0)
(11 0.0 0.0 0.0)
(210 0.0 0.0 1.0)
(100 . "AcDbText")
(73 . 0)
Edited by mhupp
Hi ronjonp! It works perfectly! I'm learning so much! Is there a way to know the true value of the height without having a fuzz filter?
Thanks guys!
Thanks guys!
Generally when working with real numbers you have to set some sort of tolerance. This is usually achieved with the EQUAL function.
If you want to see more precision use (RTOS NUMBER 2 16).
Thanks ronjonp! Very interesting!
Have a good day!
Have a good day!
.. but it did! how odd.
It is a shame you can't just do something apply a function to the ssget criteria like (40. (round 1.5688) ) if that makes sense,
