Can't copy extrusion
I am having trouble copying an extrusion i made. it will only copy certain components of it and the rest is a "block" type extrusion.
need help ASAP
thanks for the replies
HI, Not sure what you mean by a block type extrusion.
HJow was it created, in place? Is it a separate family loaded into the project?
Sometimes the elements will be pinned to their location. If you select the element and a little blue drawings pin is visible, click on this and you should be able to copy it to a new location.
It could also be constrained to only move in one direction (ie XY).
Can you post a screen shot or the file itself?
Yeah sometimes it is constrained if you built it in the project. See if you can uncheck constrain on the top when you click copy.
