Hi,
i need a simple lisp to save each opened file in ZWCAD. In ZWCAD there is no that command.
Edited by pietrow
I am not sure of the commands for ZWCAD, AutoCAD does have "saveall" command in the express tools
ZWCAD should be able to run this I think:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/zoom-extents-all-opened-drawings-lisp-routine/td-p/5402517
Google reckons that this zooms all and saves all the open drawings, take out the zoom function and away you go.
I haven't tried this yet but might in a moment
  • Thanks 1
(defun c:saveall ( / )
(vl-load-com)
 (vlax-for OpenDwgs (vla-get-documents (vlax-get-acad-object))
   (vla-save OpenDwgs)
 );; vlax-for
  • Thanks 1
Thank you, both work very well.
I have another question - is there possibility to implement for this routine to call command from created lisp like C:LISPNAME? I have about 20-30 dwg files and in every of them i need to run exact the same lisps - its time consuming and could result in omitting some dwg.
A couple of ways to do this.
I assume your saveall is saved in a LISP file somewhere.
Put the file you want with the LISP routines you want into the startup suit
Simple, but effective for 30 drawings is to put for example (c:LISPNAME) right at the end of your Lisp file, outside of the last function definition, so when CAD loads the file it will ge to that line and run it. Best to keep the (C:LISPNAME) line in the same file as the LISP just in case it hasn't been loaded when it is asked to run
Second easiest is to create a seperate LISP with all the LISPs running from that, load a drawing, run this one and it does everything for example
(defun c:runsomestuff ( / )
  (c:LISPNAME)
  (c:saveall)
  (dosomehing)
Just run that each time you open a drawing
Ad third look at something like scriptpro, and run c:runsomestuff as a batch on all the drawings
