jim78b Posted August 25, 2022 Author Share Posted August 25, 2022 7 hours ago, mhupp said: So update lido's code. ;;Changing the width of the polylines to zero if the ;;thickness of the polylines is less than zero (DEFUN C:POLY0 (/ ACDC SEL) (ssget "_X" '((0 . "*POLYLINE") (-4 . "<=") (39 . 0.1))) ;only select polylines that have widths less than or equal to 0.1 (setq ACDC (vla-get-activedocument (vlax-get-acad-object)) SEL (vla-get-activeselectionset ACDC)) (vlax-for Itm SEL (vla-put-constantwidth Itm 0) ) (princ) ) ;;C:POLY0 Ok i will try thanks a lot .i hope work with blocks and not. Quote Link to comment Share on other sites More sharing options...
jim78b Posted August 25, 2022 Author Share Posted August 25, 2022 The problem in autoca is when you have polylines global width on 0.1 /0.001 / 0.0001 .if you select a block with this polylines you don't see the highlight color ...or if you try to move the you don't see anything. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 25, 2022 Share Posted August 25, 2022 11 hours ago, jim78b said: Constant width Maybe this? (defun c:foo nil (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (if (= 0 (vlax-get b 'isxref)) (vlax-for a b (and (vlax-write-enabled-p a) (vlax-property-available-p a 'constantwidth) (<= (vla-get-constantwidth a) 0.1) (vla-put-constantwidth a 0) ) ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted August 25, 2022 Share Posted August 25, 2022 This also might be your problem. Quote Link to comment Share on other sites More sharing options...
jim78b Posted August 25, 2022 Author Share Posted August 25, 2022 THANKS A LOT you are the best and thanks to all for help me! Quote Link to comment Share on other sites More sharing options...
