jim78b Posted August 21, 2022 Posted August 21, 2022 Hello, I would need to modify this lisp, currently it brings all polylines thicknesses to 0 (even in blocks). I should bring to 0 thresholds those polylines that have thickness <0, while those that already have it at 0 or> 0 I leave them as they are. (defun c:polywidthzero ( / doc ) (vlax-for block (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (if (eq :vlax-false (vla-get-isxref block)) (vlax-for obj block (if (eq "AcDbPolyline" (vla-get-objectname obj)) (vl-catch-all-apply 'vla-put-constantwidth (list obj 0.0)) ) ) ) ) (vla-regen doc acallviewports) (princ) ) (vl-load-com) (princ) thanks to all Quote
lido Posted August 21, 2022 Posted August 21, 2022 Replace the line (if (eq "AcDbPolyline" (vla-get-objectname obj)) With the line (if (and (eq "AcDbPolyline" (vla-get-objectname obj)) (< (vla-get-thickness obj) 0)) NOT tested!! 1 Quote
jim78b Posted August 21, 2022 Author Posted August 21, 2022 Thanks very much ...so this may work ? Quote
jim78b Posted August 22, 2022 Author Posted August 22, 2022 hello i tested your modification, not work sorry Quote
lido Posted August 22, 2022 Posted August 22, 2022 Try this ;;Changing the width of all polylines to zero in all blocks in ;;the drawing if the thickness of the polylines is less than zero (DEFUN C:POLY0 (/ ACDC BNAME LSBLK REGE) (setq ACDC (vla-get-activedocument (vlax-get-acad-object))) (vlax-for el (vla-get-blocks ACDC) (setq BNAME (vla-get-name el)) (if (and (eq (vla-get-isxref el) :vlax-false) (eq (vla-get-islayout el) :vlax-false) (/= (substr BNAME 1 1) "*") (wcmatch BNAME "~*|*") (not (vl-position el LSBLK)) ) (setq LSBLK (cons el LSBLK)) ) ) (foreach Obj LSBLK (vlax-for Itm Obj (if (and (vlax-property-available-p Itm "ObjectName") (vlax-property-available-p Itm "Thickness") (= (strcase (vla-get-objectname Itm)) "ACDBPOLYLINE") (< (vla-get-thickness Itm) 0) ) (vla-put-constantwidth Itm (setq REGE 0)) ) ) ) (if REGE (vla-regen ACDC acallviewports)) (princ) ) ;;C:POLY0 1 Quote
jim78b Posted August 24, 2022 Author Posted August 24, 2022 Thanks i will try ..but i need Aldo outside blocks . Is this lisp work ? Quote
lido Posted August 24, 2022 Posted August 24, 2022 The program works only for polylines inside the block. For the entities polylines, test the thickness with the function vla-get-thickness (see above). Quote
jim78b Posted August 24, 2022 Author Posted August 24, 2022 sorry have patience, but i need that works even for polylines outside blocks. Quote
lido Posted August 24, 2022 Posted August 24, 2022 Try this ;;Changing the width of the polylines to zero if the ;;thickness of the polylines is less than zero (DEFUN C:POLY1 (/ ACDC SEL) (ssget "_X" (list (quote (0 . "*POLYLINE")) (quote (-4 . "<")) (quote (39 . 0)))) (setq ACDC (vla-get-activedocument (vlax-get-acad-object)) SEL (vla-get-activeselectionset ACDC)) (vlax-for Itm SEL (vla-put-constantwidth Itm 0)) (princ) ) ;;C:POLY1 Quote
jim78b Posted August 24, 2022 Author Posted August 24, 2022 sorry nothing happen, not work i am so sorry, Quote
lido Posted August 24, 2022 Posted August 24, 2022 For my it works! Please test the program on the attached dwg. Depending on your CAD program, maybe a regeneration of the drawing might be necessary (?) Test.dwg Quote
lido Posted August 24, 2022 Posted August 24, 2022 @mhupp Replace (vla-put-constantwidth Itm 0) with (vl-catch-all-apply (function vla-put-constantwidth) (list Itm 0)) Quote
jim78b Posted August 24, 2022 Author Posted August 24, 2022 ;;Changing the width of the polylines to zero if the ;;thickness of the polylines is less than zero (DEFUN C:POLY0 (/ ACDC SEL) (ssget "_X" (list (quote (0 . "*POLYLINE")) (quote (-4 . "<")) (quote (39 . 0)))) (setq ACDC (vla-get-activedocument (vlax-get-acad-object)) SEL (vla-get-activeselectionset ACDC)) (vlax-for Itm SEL (vl-catch-all-apply (function vla-put-constantwidth) (list Itm 0)) (princ) ) ;;C:POLY0 malformed list function ! Quote
jim78b Posted August 24, 2022 Author Posted August 24, 2022 I didn't make myself clear. I mean if I have polylines with thickness greater than 0 (blocks and not) I leave them like this. If I have polylines with thickness less than 0 (example 0.001) do I take them to 0. Clear? Quote
jim78b Posted August 24, 2022 Author Posted August 24, 2022 Oh i am so sorry !excuse i mean ...values like 0.1/ 0.001/0.0001 must be 0. But if i have other polylines that has values different from thath value is ok . So from 0.1 to 0.999999 i think must be 0. Quote
mhupp Posted August 24, 2022 Posted August 24, 2022 (edited) So update lido's code. ;;Changing the width of the polylines to zero if the ;;thickness of the polylines is less than zero (DEFUN C:POLY0 (/ ACDC SEL) (ssget "_X" '((0 . "*POLYLINE") (-4 . "<=") (39 . 0.1))) ;only select polylines that have widths less than or equal to 0.1 (setq ACDC (vla-get-activedocument (vlax-get-acad-object)) SEL (vla-get-activeselectionset ACDC)) (vlax-for Itm SEL (vla-put-constantwidth Itm 0) ) (princ) ) ;;C:POLY0 Edited August 24, 2022 by mhupp less than or equal 1 Quote
ronjonp Posted August 24, 2022 Posted August 24, 2022 41 minutes ago, jim78b said: Oh i am so sorry !excuse i mean ...values like 0.1/ 0.001/0.0001 must be 0. But if i have other polylines that has values different from thath value is ok . So from 0.1 to 0.999999 i think must be 0. Are we talking about THICKNESS or CONSTANTWIDTH ? Quote
