mladenlju Posted August 19, 2022 Share Posted August 19, 2022 Hi, is there a lisp that I can use to change the elevation of an object based on the selection of another object? For example, object 1 has an elevation of 0, and object 2 has an elevation of 155, I want object 1 to change elevation based on the selection of object 2. Of course, the X and Y coordinates of object 1 must not change. Best regards, Mladen Lj. Change elevation of object based on another.dwg Quote Link to comment Share on other sites More sharing options...
fuccaro Posted August 19, 2022 Share Posted August 19, 2022 (defun c:MoveZ( / ss target z i en el a10) (princ "Select objects to be moved...") (setq ss (ssget)) (setq target (entsel "select target ")) (setq z (last (assoc 10 (entget (car target))))) (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i))) el (entget en) a10 (reverse(cons z (cdr(reverse(assoc 10 el))))) el (subst a10 (assoc 10 el) el)) (entmod el) ) (setq ss nil) (princ) ) Here a quick one - I have just minutes until I go home. Does it help? 1 Quote Link to comment Share on other sites More sharing options...
mladenlju Posted August 19, 2022 Author Share Posted August 19, 2022 Thx for help. It's work. In the meantime i got this one (also work): (defun c:Zmatch ( / s d) (and (setq s (car (entsel "\nSource: "))) (setq s (last (assoc 10 (entget s)))) (setq d (car (entsel (strcat "\nObject to apply z=" (rtos s) " to: ")))) (setq d (entget d)) (entmod (subst (reverse (cons s (cdr (reverse (assoc 10 d))))) (assoc 10 d) d)) ) (princ) ) br Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted August 19, 2022 Share Posted August 19, 2022 Maybe this post can help you Quote you only need to select a point on the object. Quote Link to comment Share on other sites More sharing options...
dan20047 Posted August 19, 2022 Share Posted August 19, 2022 I use the .xyz shortcuts (defun c:MX () (ssget ":LI") (SAA_CMDACTIVE nil) (command "MOVE" "P" "" pause ".yz" "non" "@") (princ)) (defun c:MY () (ssget ":LI") (SAA_CMDACTIVE nil) (command "MOVE" "P" "" pause ".xz" "non" "@") (princ)) (defun c:MZ () (ssget ":LI") (SAA_CMDACTIVE nil) (command "MOVE" "P" "" pause ".xy" "non" "@") (princ)) ;;;========================================================== ;;; Continue pausing until exited command mode ;;; nil = pause ;;; otherwise pass string to use ;;; credit unknown ;;; usage example: (command "line" (SAA_CMDACTIVE nil)) ;;;========================================================== (defun SAA_CMDACTIVE ( passcmd / ) (if (null passcmd) (setq passcmd pause)) (while (not (= 0 (getvar "cmdactive"))) (if (= 'LIST (type passcmd)) (foreach x passcmd (command x) ) ;_foreach (command passcmd) ) ;_if ) ;end while ) 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 23, 2022 Share Posted August 23, 2022 As your dealing with objects with possible Z values, the entmod would be more reliable method. Else check is object to move at z=0. Quote Link to comment Share on other sites More sharing options...
