DCL multiple text boxes in line and file selection?
TemporaryCAD
How would I go about making something like this:
Additionally, would it be possible to embed the (getfiled) window into a DCL window, so I can have file selection at the same time as data entry?
This is my first time using DCL, and I haven't had much luck finding resources relating to these questions.  Thanks!
A good resource for making DCL
https://autolisp-exchange.com/Tutorials/MyDialogs.htm
(setq total (rtos (length (setq lst (layoutlist)))2 0)) ;total number of layouts
(setq pos (rtos (+ (vl-position (getvar 'ctab) lst) 1)2 0)) ;find the postion in the list
(prompt (strcat "\n" pos " of " total)); output "1 of 3"
--edit
See what rlx did here
Edited by mhupp
I found a hacky workaround - Here's an image:
And here's the dcl for the row:
: row {
      : edit_box{
      label = "Enter Sheet Number:                                                           ";
      mnemonic = "S";
      key = "number";
      alignment = right;
      edit_limit = 2;
      edit_width = 2;
      : edit_box{
      label = "of";
      key = "number2";
      alignment = left;
      edit_limit = 2;
      edit_width = 2;
It turns out adding a bunch of spaces will mess with the spacing.  I hope this helps someone else!
Edited by TemporaryCAD
Maybe this as an alternative can be made into more input  lines.
Multi GETVALS.lsp
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter sheet values " "Sheet number  " 5 4 "1" "Of " 5 4 "x")))
Edited by BIGAL
