Hi every one i have a problem with my lisp does any one here can help me this is my problem:
i want to rotate my object with vla-rotate in while but when you run this program the line will rotate to much please help
(DEFUN C:TEST ()
  ;DRAW PLINE
  (SETQ P1 (GETPOINT "\nSpecify first point: ")
        P2 (POLAR P1 0 5.0)
        P3 (POLAR P2 (/ PI 2.0) 1.0)
        P-LST (APPLY 'APPEND (LIST P1 P2 P3))
        P-LST (VLAX-SAFEARRAY-FILL (VLAX-MAKE-SAFEARRAY VLAX-VBDOUBLE (CONS 0 (- (LENGTH P-LST) 1))) P-LST)
  (SETQ OBJ (VLA-ADDPOLYLINE (VLA-GET-MODELSPACE (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT))) P-LST))
  ;VLA-ROTATE
  (PRINC "\nSpecify second point: ")
  (WHILE (MEMBER (CAR (SETQ GR (GRREAD T 15 0))) '(5 2))
    (IF (LISTP (CADR GR))
      (VLA-ROTATE OBJ (VLAX-3D-POINT P1) (ANGLE P1 (CADR GR)))
    (IF (= (CADR GR) 15)
      (SETVAR 'ORTHOMODE (- 1 (GETVAR 'ORTHOMODE)))
Rotate command does like the grread or am I missing something, your drawing a "L" then rotating it. You could certainly do a dummy xline etc  line from p1 to wanted angle pick point  then use that to rotate (entlast).
Hi Bigal actually I want to draw "L" for user but user must specify the angle of "L" but i want the user see the object and rotate.
I know i have simple option like ask the angle from user in first place and then draw "L" but i like user able to see the object and after that specify the angle of it
Actually i use this part as well
(SETQ SS (SSADD (VLAX-VLA-OBJECT->ENAME OBJ)))
  (WHILE SS
    (SETQ ANG (ACET-SS-DRAG-ROTATE SS (TRANS P1 0 1) "\nSpecify second point: "))
    (SETQ SS NIL)
but it have a little problem ACET-SS-DRAG-ROTATE keep first object and create illustrator of first object
I don't know about showing the object itself but you can show the rotation angle.
(defun C:TEST (/ drawing util MS P1 P2 P3 P-LST OBJ ANG)
  (vl-load-com)
  (setq drawing (vla-get-activedocument (vlax-get-acad-object))
        util (vla-get-utility drawing)
        MS (vla-get-modelspace drawing)
        P1 (getpoint "\nSpecify first point: ")
        P2 (polar P1 0 5.0)
        P3 (polar P2 (/ PI 2.0) 1.0)
        P-LST (apply 'append (list P1 P2 P3))
        P-LST (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 (- (lenght P-LST) 1))) P-LST) ;not needed in briscad
        OBJ (vla-addpolyline MS P-LST)
        ang (vla-getangle util p1 "\nRotation Angle: ")
  (vla-rotate OBJ P1 ang)
  (vl-load-com)
        P2 (polar P1 0 5.0)
actually I found a solution for this:
(DEFUN C:TEST ()
  ;DRAW PLINE
        P2 (POLAR P1 0 5.0)
  (VL-CMDF "._FILLET" "_p" "_r" 0.3 (VLAX-VLA-OBJECT->ENAME OBJ))
  ;VLA-ROTATE
  (SETQ ANG-TEMP 0)
  (WHILE (MEMBER (CAR (SETQ GR (GRREAD T 15 0))) '(5))
      (PROGN
        (SETQ ANG (ANGLE P1 (CADR GR)))
        (VLA-ROTATE OBJ (VLAX-3D-POINT P1) (- ANG ANG-TEMP))
    (SETQ ANG-TEMP ANG)
