Delete viewport in a layout containing only one viewport (and nothing else)
I am trying to delete the viewport on a layout containing only one viewport (and nothing else).
Can anyone please help?
Edited by w64bit
  • w64bit changed the title to Delete viewport in a layout containing only one viewport (and nothing else)
Try this .. does not check for locked layers:
(defun c:foo (/ s)
  (foreach l (layoutlist)
    (and (setq s (ssget "_X" (list (cons 410 l))))
	 (= 2 (sslength s))
	 (setq s (mapcar 'cadr (ssnamex s)))
	 (= "VIEWPORT" (cdr (assoc 0 (entget (car s)))) (cdr (assoc 0 (entget (cadr s)))))
	 (mapcar 'vla-delete (mapcar 'vlax-ename->vla-object s))
It's working very well.
Thank you very much.
Glad to help 🍻
