It is a know fact that sometimes a lisp will fail due to scale of current view, has been for years a problem. My suggestion would be look at (setvar 'osmode 0) in your code, even osmode 1 "endpoint" is enough to snap to wrong points, you can reset osmode as often as you need in your code. 0 works for me 16384 is all off.
  • Replies 25
  • Abrasive
    10
  • Jamescalabut
    4
  • Jonathan Handojo
    4
  • mhupp
    3
Posted Images
 @BIGAL,
I see osmde 16384 is like selecting nothing and also clicking F3 (object  Reference OFF), which avoids those silly fails in lisp programs.
I've been using "osmode" 0 due to my lack of knowledge, but your idea is far better.
Thanks,
Here is my attempt. only need the two points and width. then use boundary to create the "rectangle". Should work 100% of the time unless the side entity's are two short or something is in between them.
--edit
or if you pick points are not close to the side entity's so that the mpt isn't in between them.
(defun C:FOO (/ ss dist pt1 pt2 mpt vec line)
  (setq ss (ssadd))
  (setq dist (/ (getreal "\nWidth: ") 2.0)
        pt1 (getpoint "\nSelect First Point:")
        pt2 (getpoint pt1 "\nSelect Scond Point:")
        MPT (mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2))
        vec (mapcar '/ (mapcar '- pt2 pt1) (list (distance pt1 pt2) (distance pt1 pt2) (distance pt1 pt2)))
  (entmake (list '(0 . "XLINE") '(100 . "AcDbEntity") '(100 . "AcDbXline") (cons 10 pt1) (cons 11 vec)))
  (setq line (vlax-ename->vla-object (entlast)))
  (vla-offset line dist)
  (ssadd (entlast) ss)
  (vla-offset line (- dist))
  (vla-delete line)
  (vl-cmdf "_.-Boundary" "_non" MPT "")
  (vl-cmdf "_.Erase" SS "")
Edited by mhupp
Nice idea making a bpoy etc, so much easier than calcs of intersectwith,  if want to keep the base line add (command "OOPS") after creating boundary and it will reappear.
I like it!
The XLINES don't erase when I run it though? maybe a setting I need to change?
Thanks
Check to see if current layer is locked?
