The AutoCAD Blog Posted July 26, 2022 Share Posted July 26, 2022 We’re excited to share another Have You Tried article with you this month. Ever needed to place several evenly spaced objects like a block of a light post, or trees along a street or walking path? You might have evaluated the length, did a little math, and then figured out how far apart each object needed to be. But there’s a faster way! DIVIDE and MEASURE can help you to divide an object equally or based on a specific interval, and place points or blocks along an object. In this Have You Tried, we’ll cover how to perform the following: Set a point styleDivide an object with the DIVIDE and MEASURE commandsPlace blocks at equal intervals Learn about the DIVIDE and MEASURE commands in AutoCAD with the step-by-step examples in Have You Tried: Divide and Measure Commands topic. Keep the Feedback Coming Thanks for all the great feedback submitted so far. Because of the great feedback, we have been able to improve the topics in the AutoCAD Online Help system. The best way to submit feedback is by using the “Was this helpful?” section located at the bottom of every Help topic. Let us know what you like or don’t like about a topic or provide suggestions for other subjects that you’d like to see covered in greater detail. The more specific your comments, the better. The post Have You Tried: Divide and Measure Commands appeared first on AutoCAD Blog. View the full article Quote Link to comment Share on other sites More sharing options...
Neha gi Posted September 17, 2022 Share Posted September 17, 2022 Using DIVIDE and MEASURE commands of AutoCAD you can divide 2D drawing objects like Line, Polyline, Arc, Spline and Ellipse in equal parts without knowing their length. These commands will not split the geometry instead at every division a point will be added. Quote Link to comment Share on other sites More sharing options...
