itacad Posted July 25, 2022 Posted July 25, 2022 Hi, when printing to PDF, a file is created with the name composed of the dwg filename + the name of the layout ... It is possible to have the name of the PDF file proposed as: - file name of the dwg or - layout name This is to avoid continuous renaming of the created files Greetings Quote
BIGAL Posted July 25, 2022 Posted July 25, 2022 Posted elsewhere but anyway (setq pdfname (strcat (getvar "dwgprefix") dwgname "-" (getvar "ctab"))) Quote
CyberAngel Posted July 28, 2022 Posted July 28, 2022 Have you used the Sheet Set Manager? It may do what you want. Quote
itacad Posted August 1, 2022 Author Posted August 1, 2022 On 7/28/2022 at 2:49 PM, CyberAngel said: Have you used the Sheet Set Manager? It may do what you want. Mmmh..I don't use this function...I'll read about it but but I don't think it will solve...let's hope so! thank you Quote
