Measure a polyline with a block and stop after inserting first block.
I want to insert a block at a given distance from a start end of a polyline.
Pl. can somebody give me a code.
Need a little more information or a sample drawing.
Must have just read title
Assumes start end of poly are same distance.  Easy enough using vlax-curve-getpointatdist. error check to see if distance is less than 1/2 the distance of the polyline. or the start block would be past the end block on the polyline.
;; INSERT BLOCK AT DISTANCE FROM ENDPOINTS ON POLYLINE
(defun C:foo (/ dist poly Spt Ept)
  (vl-load-com)
  (setvar 'cmdecho 0)
  (setq dist (getdist "\nDistance from ends of poyline: "))
  (setq poly (vlax-ename->vla-object (car (entsel "\nSelect Polyline: "))))
  (if (< dist (/ (vla-get-length poly) 2))
      (setq Spt (vlax-curve-getpointatdist poly dist))
      (command "_.Insert" blockname "_non" Spt "" "" "")
      (setq Ept (vlax-curve-getpointatdist poly (- (vla-get-length poly) dist)))
      (command "_.Insert" blockname "_non" Ept "" "" "")
    (prompt "\nDistance is to large")
  (setvar 'cmdecho 1)
Edited by mhupp
cmdecho and princ
Along the polyline? Look at chainage LISPS, there are some that will place a block there and I think will have a repeat or while loop as it iterates along the line, maybe all you need is to take that out to get the first distance.
  • Agree 1
