3dwannab Posted July 21, 2022 Share Posted July 21, 2022 I want to be able to copy a locked layer to a new one with the COPYTOLAYER command. I've tried to get around this by unlocking the layers before, then after the COPYTOLAYER command. This will throw an error like so when I try to copy a locked layer: Here's the code: (vl-load-com) ;; PROBLEM ;; AutoCAD gives unhandled exception error with eOnLockedLayer. ;; TO ADD ;; Change this to have undo handling (defun c:Lay_Copy_Locked (/ layUlist laydata ss) (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))) ; Unlock all layers - https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/unlocking-layers-is-painfully-slow/m-p/2881866#M294136 (vlax-for item (vla-get-layers doc) (if (= (vlax-get-property item "Lock") :vlax-true) (progn (setq Locked_Layers (cons item Locked_Layers)) ; set variable "locked_layers" to all locked layers. (vlax-put-property item "Lock" :vlax-false) ; unlock each layer if it is locked. ) ; end progn ) ; end if ) ; end vlax ;; Copy to layer (if (setq ss (ssget "_:L")) (command "._-copytolayer" ss "") ) ; end if ; If any layers were locked at the beginning, lock them again. -https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/unlocking-layers-is-painfully-slow/m-p/2881866#M294136 (if Locked_Layers (mapcar '(lambda (x) (vlax-put-property x "Lock" :vlax-true)) Locked_Layers) ) ; end if (princ) ) ; defun (c:Lay_Copy_Locked) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted July 21, 2022 Share Posted July 21, 2022 (defun c:Lay_Copy_Locked ( / *error* layUlist laydata ss ) (vl-load-com) (defun *error* ( m ) (if command-s (command-s "_.UNDO" "_E") (vl-cmdf "_.UNDO" "_E") ) (if m (prompt m) ) (princ) ) (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))) (if (= 8 (logand 8 (getvar 'undoctl))) (if command-s (command-s "_.UNDO" "_E") (vl-cmdf "_.UNDO" "_E") ) ) (if command-s (command-s "_.UNDO" "_G") (vl-cmdf "_.UNDO" "_G") ) ; Unlock all layers - https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/unlocking-layers-is-painfully-slow/m-p/2881866#M294136 (vlax-for item (vla-get-layers doc) (if (= (vlax-get-property item "Lock") :vlax-true) (progn (setq Locked_Layers (cons item Locked_Layers)) ; set variable "locked_layers" to all locked layers. (vlax-put-property item "Lock" :vlax-false) ; unlock each layer if it is locked. ) ; end progn ) ; end if ) ; end vlax ;; Copy to layer (if (setq ss (ssget "_:L")) (command "._-copytolayer" ss "") ) ; end if ; If any layers were locked at the beginning, lock them again. -https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/unlocking-layers-is-painfully-slow/m-p/2881866#M294136 (if Locked_Layers (mapcar '(lambda (x) (vlax-put-property x "Lock" :vlax-true)) Locked_Layers) ) ; end if (*error* nil) ) ; defun 1 Quote Link to comment Share on other sites More sharing options...
