Janeth Posted July 20, 2022 Posted July 20, 2022 Did anyone have used Advance Steel for lattice truss structures? My requirements for Autodesk Advance Steel: - steel lattice design (e.g. electrical substation support, isolator support, transformer support) - simple connection (e.g. angle to angle bolted connection) - 3D grid (or skeleton) constrained design (i.e. overall dimensions can drive design) - arrayed braces (if possible) -plates connections for 2 o 3 diagonals. -Base plates I Quote
BIGAL Posted July 21, 2022 Posted July 21, 2022 (edited) I posted an answer it was here. Radio towers ? Again maybe something exists or else a custom program required. If your in that industry find out what your competitor uses if you have friends in other companies. Pretty sure last comment involved $$$ so poster went away. The lattice is a repeating pattern yes it could be coded, build quantities etc also. Edited July 21, 2022 by BIGAL Quote
oddssatisfy Posted March 9, 2024 Posted March 9, 2024 On 7/21/2022 at 2:39 AM, Janeth said: Did anyone have used Advance Steel for lattice truss structures? My requirements for Autodesk Advance Steel: - steel lattice design (e.g. electrical substation support, isolator support, transformer support) - simple connection (e.g. angle to angle bolted connection) - 3D grid (or skeleton) constrained design (i.e. overall dimensions can drive design) - arrayed braces (if possible) -plates connections for 2 o 3 diagonals. -Base plates I Portal frame steel building I'm looking at building a small commercial bldg. as per submitted photo (50'x 120'), with wall heights in excess of 20'. With the availability of engineered wood products achieving enhanced structural capabilities, I am curious why such projects are seemingly few and far between? Any feedback would be welcome. Quote
BIGAL Posted March 10, 2024 Posted March 10, 2024 Concrete tilt panels used all over the world nothing new, lots and lots of stuff out there. Structural timber has always been a specialist engineering task and I had the privilige of working with a company that specialized in timber structures. Laminated joints with nailing, bolted joints, shear connecters and so on. Yes pretty well drawn 1 by one. Some stuff always look back could be automated particularly connections, nails or bolts. Quote
