INVERTED FILLET HELP..
leonucadomi
IS THERE ANY WAY TO MAKE AN INVERTED FILLET?
ASK THE RADIO
SELECT BOTH LINES
AND WHAT IS DRAWN
I APPRECIATE YOUR COMMENTS
THANKS
(defun c:inv_fillet ( / *error* ftoa cmd rad r p pp pl ss i e el ex par flag k )
  (vl-load-com)
  (defun *error* ( m )
    (if command-s
      (command-s "_.UNDO" "_E")
      (vl-cmdf "_.UNDO" "_E")
    (if cmd
      (setvar 'cmdecho cmd)
    (if m
      (prompt m)
  (defun ftoa ( n / m a s b )
    (if (numberp n)
        (setq m (fix ((if (< n 0) - +) n 1e-8)))
        (setq a (abs (- n m)))
        (setq m (itoa m))
        (setq s "")
        (while (and (not (equal a 0.0 1e-6)) (setq b (fix (* a 10.0))))
          (setq s (strcat s (itoa b)))
          (setq a (- (* a 10.0) b))
        (if (= (type n) 'int)
          m
          (if (= s "")
            m
            (if (and (= m "0") (< n 0))
              (strcat "-" m "." s)
              (strcat m "." s)
  (setq cmd (getvar 'cmdecho))
  (setvar 'cmdecho 1)
  (if (= 8 (logand 8 (getvar 'undoctl)))
  (vl-cmdf "_.UNDO" "_G")
  (setq rad (getvar 'filletrad))
  (initget 6)
  (setq r (getdist (strcat "\nPick or specify radius of fillet <" (ftoa rad) "> : ")))
  (if (not r)
    (setq r rad)
  (setvar 'filletrad r)
  (prompt "\nENTER FOR PICK CURVES - 2 SEGMENTS, ELSE SELECT POLYLINES...")
  (if
    (if (ssget "_A" '((0 . "*POLYLINE")))
      (not (setq ss (ssget "_:L" '((0 . "*POLYLINE")))))
      t
      (setq p (getvar 'lastpoint) el (entlast))
      (vl-cmdf "_.FILLET")
      (while (< 0 (getvar 'cmdactive))
        (vl-cmdf "\\")
        (if (not (equal p (setq pp (getvar 'lastpoint)) 1e-6))
          (setq pl (cons pp pl))
      (if (not (eq el (entlast)))
        (if (= (cdr (assoc 0 (setq ex (entget (entlast))))) "ARC")
          (entupd (cdr (assoc -1 (entmod (mapcar (function (lambda ( x ) (cond ( (= (car x) 50) (cons 50 (cdr (assoc 51 ex))) ) ( (= (car x) 51) (cons 51 (cdr (assoc 50 ex))) ) ( t x )))) ex)))))
        (if (wcmatch (cdr (assoc 0 (setq ex (entget (car (nentselp (osnap (car pl) "_nea"))))))) "*POLYLINE,VERTEX")
            (if (wcmatch (cdr (assoc 0 ex)) "POLYLINE,VERTEX")
              (cond
                ( (= (cdr (assoc 0 ex)) "VERTEX")
                  (setq ex (entget (cdr (assoc 330 ex))))
                  (vl-cmdf "_.CONVERTPOLY" "_L" (cdr (assoc -1 ex)) "")
                  (setq ex (entget (cdr (assoc -1 ex))))
                  (setq flag t)
                ( (= (cdr (assoc 0 ex)) "POLYLINE")
                  (setq flag t)
            (if (= (cdr (assoc 0 ex)) "LWPOLYLINE")
              (if (> (abs (fix (- (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (car pl))) (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (cadr pl)))))) 1.0)
                (if (= (cdr (assoc 42 ex)) 0.0)
                  (entupd (cdr (assoc -1 (entmod (subst (cons 42 (- (/ 1.0 (cdr (assoc 42 (reverse ex)))))) (assoc 42 (reverse ex)) ex)))))
                  (entupd (cdr (assoc -1 (entmod (subst (cons 42 (- (/ 1.0 (cdr (assoc 42 ex))))) (assoc 42 ex) ex)))))
                  (setq par (/ (+ (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (car pl))) (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (cadr pl)))) 2.0))
                  (entupd (cdr (assoc -1 (entmod (mapcar (function (lambda ( x ) (if (= (car x) 42) (progn (setq k (if (not k) 0 (1+ k))) (if (= k (fix par)) (if (/= (cdr x) 0.0) (cons 42 (- (/ 1.0 (cdr x)))) (cons 42 0.0)) x)) x))) ex)))))
            (if flag
              (vl-cmdf "_.CONVERTPOLY" "_H" (cdr (assoc -1 ex)) "")
    (if ss
        (setq e (ssname ss (setq i (1- i))))
        (vl-cmdf "_.FILLET" "_P" e)
          (vl-cmdf "")
        (setq ex (entget e))
          (cond
              (setq flag t)
              (setq flag t)
          (entupd (cdr (assoc -1 (entmod (mapcar (function (lambda ( x ) (if (and (= (car x) 42) (/= (cdr x) 0.0)) (cons 42 (- (/ 1.0 (cdr x)))) x))) ex)))))
        (if flag
        (setq flag nil)
  (*error* nil)
Edited by marko_ribar
Maybe draw circle at int of 2 lines then trim circle and lines, do TRIM then Window selection over the circle and lines, Enter, select 2 lines inside circle, then diagonal opposite corner to circle, ie remove outside. All done. No code needed. Yes could be coded.
Edited by BIGAL
I have the routines that do it but separated and I don't know how to join them  :(
1.lsp 2.lsp test.dwg
(defun c:corner_chamfer_arc ( / *error* ftoa catch_cont unit mid v^v MR:3pcircle MR:3parc cmd pea rad r p pp pl c arc1 arc2 p1 p2 p3 p4 ss s i e el ex par flag flagg k ptl ptlpairs pair n )
  (vl-load-com)
    (if command-s
    (if cmd
    (if pea
      (setvar 'peditaccept pea)
    (if m
      (prompt m)
    (if (numberp n)
        (setq m (itoa m))
        (setq s "")
          m
          (if (= s "")
            m
              (strcat m "." s)
  (defun catch_cont ( / catch )
    (prompt "\nleft mouse click to continue or enter to generate catch error - ESC to break...")
    (while (and (or (not (equal (grread) '(2 13))) (not (vl-catch-all-error-p (setq catch (vl-catch-all-apply (function /) (list 1 0)))))) (/= (car (grread)) 3)))
    (if (vl-catch-all-error-p catch)
      catch
  (defun unit ( v / d )
    (if (not (equal (setq d (distance (list 0.0 0.0 0.0) v)) 0.0 1e-8))
      (mapcar (function (lambda ( x ) (/ x d))) v)
        (prompt "\ncatched error in (unit) - strength of reference vector near 0.0")
        (if (vl-catch-all-error-p (catch_cont))
  (defun mid ( p1 p2 )
    (mapcar (function (lambda ( a b ) (/ (+ a b) 2.0))) p1 p2)
  (defun v^v ( u v )
    (list
      (- (* (cadr u) (caddr v)) (* (caddr u) (cadr v)))
      (- (* (caddr u) (car v)) (* (car u) (caddr v)))
      (- (* (car u) (cadr v)) (* (cadr u) (car v)))
  ;; 3-Point Circle  -  M.R. ;;
  ;; Returns the center (WCS) and radius of the circle defined by three supplied points - all 3 points in (WCS) ;;
  (defun MR:3pcircle ( pt1 pt2 pt3 / cen md1 md2 vc1 vc2 ocs ci )
    (if
      (and
        (setq md1 (mid pt1 pt2))
        (setq md2 (mid pt2 pt3))
        (setq vc1 (v^v (mapcar (function -) pt2 pt1) (setq ocs (v^v (mapcar (function -) pt3 pt1) (mapcar (function -) pt2 pt1)))))
        (setq vc2 (v^v (mapcar (function -) pt3 pt2) ocs))
        (setq cen (inters
                    md1 (mapcar (function +) md1 vc1)
                    md2 (mapcar (function +) md2 vc2)
                    nil
      (list cen (distance cen pt1))
  ;; 3-Point Arc  -  M.R. ;;
  ;; Returns ARC entity in 3D space - arguments pt1, pt2, pt3 - all 3 points in (WCS) ;;
  (defun MR:3parc ( pt1 pt2 pt3 / lst ocs )
    (if (and (setq ocs (unit (v^v (mapcar (function -) pt3 pt1) (mapcar (function -) pt2 pt1)))) (setq lst (MR:3pcircle pt1 pt2 pt3)))
        (if (minusp (sin (- (angle (trans pt1 0 ocs) (trans pt3 0 ocs)) (angle (trans pt1 0 ocs) (trans pt2 0 ocs)))))
          (mapcar (function set) (list (quote pt1) (quote pt3)) (list pt3 pt1))
        (entmakex
          (list
            (cons 0 "ARC")
            (cons 10 (trans (car lst) 0 ocs))
            (cons 40 (cadr lst))
            (cons 50 (angle (trans (car lst) 0 ocs) (trans pt1 0 ocs)))
            (cons 51 (angle (trans (car lst) 0 ocs) (trans pt3 0 ocs)))
            (cons 210 ocs)
  (setvar 'cmdecho 1)
  (setq pea (getvar 'peditaccept))
  (setvar 'peditaccept 1)
  (initget 6)
  (if (not r)
    (setq r rad)
  (setvar 'chamfera r)
  (setvar 'chamferb r)
  (if
      t
      (vl-cmdf "_.CHAMFER")
        (vl-cmdf "\\")
        (if (= (cdr (assoc 0 (setq ex (entget (entlast))))) "LINE")
            (setq c (inters (vlax-curve-getpointatparam (setq e (car (nentselp (osnap (car pl) "_nea")))) (- (vlax-curve-getparamatpoint e (vlax-curve-getclosestpointto e (car pl))) 0.05)) (vlax-curve-getpointatparam (setq e (car (nentselp (osnap (car pl) "_nea")))) (+ (vlax-curve-getparamatpoint e (vlax-curve-getclosestpointto e (car pl))) 0.05)) (vlax-curve-getpointatparam (setq e (car (nentselp (osnap (cadr pl) "_nea")))) (- (vlax-curve-getparamatpoint e (vlax-curve-getclosestpointto e (cadr pl))) 0.05)) (vlax-curve-getpointatparam (setq e (car (nentselp (osnap (cadr pl) "_nea")))) (+ (vlax-curve-getparamatpoint e (vlax-curve-getclosestpointto e (cadr pl))) 0.05)) nil))
            (setq arc1 (MR:3parc (cdr (assoc 10 ex)) (mapcar (function +) (mapcar (function *) (unit (mapcar (function -) (mid (cdr (assoc 10 ex)) (cdr (assoc 11 ex))) c)) (list r r r)) c) (cdr (assoc 11 ex))))
            (setq arc2 (MR:3parc (cdr (assoc 10 ex)) (mapcar (function +) (mapcar (function *) (unit (mapcar (function -) c (mid (cdr (assoc 10 ex)) (cdr (assoc 11 ex))))) (list r r r)) c) (cdr (assoc 11 ex))))
            (if (< (vla-get-arclength (vlax-ename->vla-object arc1)) (vla-get-arclength (vlax-ename->vla-object arc2)))
              (entdel arc2)
              (entdel arc1)
            (entdel (cdr (assoc -1 ex)))
              (cond
                  (setq flag 1)
                  (setq flag 1)
                  (setq c (inters (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (- (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (car pl))) 0.05)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (+ (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (car pl))) 0.05)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (- (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (cadr pl))) 0.05)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (+ (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (cadr pl))) 0.05)) nil))
                  (setq arc1 (MR:3parc (vlax-curve-getstartpoint (cdr (assoc -1 ex))) (mapcar (function +) (mapcar (function *) (unit (mapcar (function -) (mid (vlax-curve-getstartpoint (cdr (assoc -1 ex))) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (1- (vlax-curve-getendparam (cdr (assoc -1 ex)))))) c)) (list r r r)) c) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (1- (vlax-curve-getendparam (cdr (assoc -1 ex)))))))
                  (setq arc2 (MR:3parc (vlax-curve-getstartpoint (cdr (assoc -1 ex))) (mapcar (function +) (mapcar (function *) (unit (mapcar (function -) c (mid (vlax-curve-getstartpoint (cdr (assoc -1 ex))) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (1- (vlax-curve-getendparam (cdr (assoc -1 ex)))))))) (list r r r)) c) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (1- (vlax-curve-getendparam (cdr (assoc -1 ex)))))))
                    (entdel arc2)
                    (entdel arc1)
                  (entupd (cdr (assoc -1 (entmod (subst (cons 70 (* 128 (getvar 'plinegen))) (assoc 70 ex) ex)))))
                  (setq s (ssadd))
                  (cond
                    ( (not (vlax-erased-p arc1))
                      (ssadd arc1 s)
                    ( (not (vlax-erased-p arc2))
                      (ssadd arc2 s)
                  (ssadd (cdr (assoc -1 ex)) s)
                  (vl-cmdf "_.PEDIT" "_M" s "" "_J")
                    (vl-cmdf "")
                  |; ;;; for AutoCAD
                  (vl-cmdf "_.JOIN" s "") ;;; for BricsCAD
                  (setq par (- (max (fix (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (car pl)))) (fix (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getclosestpointto (cdr (assoc -1 ex)) (cadr pl))))) 0.5))
                  (setq p1 (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (- par 0.5)) p2 (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (+ par 0.5)))
                  (setq arc1 (MR:3parc p1 (mapcar (function +) (mapcar (function *) (unit (mapcar (function -) (mid p1 p2) c)) (list r r r)) c) p2))
                  (setq arc2 (MR:3parc p1 (mapcar (function +) (mapcar (function *) (unit (mapcar (function -) c (mid p1 p2))) (list r r r)) c) p2))
                    (entdel arc2)
                    (entdel arc1)
                  (vl-cmdf "_.BREAK" (cdr (assoc -1 ex)) "" "_non" (trans p1 0 1) "_non" (trans p2 0 1))
                  (setq s (ssadd))
                  (cond
                      (ssadd arc1 s)
                      (ssadd arc2 s)
                  (ssadd (car (nentselp (osnap (cadr pl) "_nea"))) s)
                  (ssadd (car (nentselp (osnap (car pl) "_nea"))) s)
                    (vl-cmdf "")
                  |; ;;; for AutoCAD
            (if flag
    (if ss
          (cond
              (setq flag 1)
              (setq flag 1)
        (if (= 1 (logand 1 (cdr (assoc 70 (setq ex (entget e))))))
            (setq ptl (mapcar (function cdr) (vl-remove-if (function (lambda ( x ) (/= (car x) 10))) ex)))
            (setq ptlpairs (mapcar (function (lambda ( a b ) (list a b))) ptl (append (cdr ptl) (list (car ptl)))))
            (setq pair (car (vl-sort ptlpairs (function (lambda ( a b ) (> (distance (car a) (cadr a)) (distance (car b) (cadr b))))))))
            (setq flagg 1)
            (vl-cmdf "_.BREAK" e "" "_non" (trans (polar (mid (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (car pair) (list (cdr (assoc 38 ex)))) e 0)))))) (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (cadr pair) (list (cdr (assoc 38 ex)))) e 0))))))) (angle (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (car pair) (list (cdr (assoc 38 ex)))) e 0)))))) (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (cadr pair) (list (cdr (assoc 38 ex)))) e 0))))))) 0.05) 0 1) "_non" (trans (polar (mid (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (car pair) (list (cdr (assoc 38 ex)))) e 0)))))) (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (cadr pair) (list (cdr (assoc 38 ex)))) e 0))))))) (angle (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (car pair) (list (cdr (assoc 38 ex)))) e 0)))))) (vlax-curve-getpointatparam e (float (fix (+ 0.1 (vlax-curve-getparamatpoint e (trans (append (cadr pair) (list (cdr (assoc 38 ex)))) e 0))))))) -0.05) 0 1))
        (vl-cmdf "_.CHAMFER" "_P" e)
          (vl-cmdf "")
        (repeat (fix (/ (+ 0.1 (setq n (1- (vlax-curve-getendparam (cdr (assoc -1 ex)))))) 2.0))
          (setq par (+ (setq n (- n 2.0)) 1.5))
          (setq p1 (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (rem (- par 0.5) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))) p2 (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (rem (+ par 0.5) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))))
          (setq c (inters (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (- (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (float (rem (1- par) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))))) 0.05)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (+ (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (float (rem (1- par) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))))) 0.05)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (- (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (float (rem (1+ par) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))))) 0.05)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (+ (vlax-curve-getparamatpoint (cdr (assoc -1 ex)) (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (float (rem (1+ par) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))))) 0.05)) nil))
            (entdel arc2)
            (entdel arc1)
          (setq p3 (trans (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (float (rem (1- par) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex)))))))) 0 1) p4 (trans (vlax-curve-getpointatparam (cdr (assoc -1 ex)) (float (rem (1+ par) (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex)))))))) 0 1))
          (setq s (ssadd))
          (cond
              (ssadd arc1 s)
              (ssadd arc2 s)
          (ssadd (car (nentselp p3)) s)
          (ssadd (car (nentselp p4)) s)
            (vl-cmdf "")
          |; ;;; for AutoCAD
        (if flagg
            (if (not (eq (cdr (assoc -1 ex)) (entlast)))
            (setq n (fix (+ 0.1 (vlax-curve-getendparam (cdr (assoc -1 ex))))))
            (setq ex (mapcar (function (lambda ( x ) (if (= (car x) 10) (progn (setq k (if (not k) 0 (1+ k))) (if (or (= k 0) (= k n)) 1 x)) x))) ex))
            (setq k nil)
            (setq ex (append (reverse (cdr (member 1 (cdr (member 1 (reverse ex)))))) (member (assoc 10 (cdr (member 1 ex))) (reverse (cdr (member 1 (reverse ex))))) (cdr (member 1 (cdr (member 1 ex))))))
            (setq ex (subst (cons 90 (1- n)) (assoc 90 ex) ex))
            (setq ex (subst (cons 70 (1+ (* 128 (getvar 'plinegen)))) (assoc 70 ex) ex))
            (entupd (cdr (assoc -1 (entmod ex))))
            |; ; something's wrong with this version - try to debug if you want ;
            (vl-cmdf "_.TRIM" "_L" "" "_non" (trans (vlax-curve-getstartpoint (entlast)) 0 1) "_non" (trans (vlax-curve-getendpoint (entlast)) 0 1) "")
            (vla-put-closed (vlax-ename->vla-object (entlast)) :vlax-true)
        (if flag
        (setq flag nil flagg nil)
  (*error* nil)
(defun c:corner_inv_chamfer_arc ( / *error* ftoa catch_cont unit mid v^v MR:3pcircle MR:3parc cmd pea rad r p pp pl c arc1 arc2 p1 p2 p3 p4 ss s i e el ex par flag flagg k ptl ptlpairs pair n )
  (vl-load-com)
    (if command-s
    (if cmd
    (if pea
    (if m
      (prompt m)
    (if (numberp n)
        (setq m (itoa m))
        (setq s "")
          m
          (if (= s "")
            m
              (strcat m "." s)
      catch
  (defun unit ( v / d catch )
  (defun v^v ( u v )
    (list
    (if
      (and
        (setq cen (inters
                    nil
        (entmakex
          (list
            (cons 0 "ARC")
            (cons 210 ocs)
  (setvar 'cmdecho 1)
  (initget 6)
  (if (not r)
    (setq r rad)
  (if
      t
        (vl-cmdf "\\")
              (entdel arc1)
              (entdel arc2)
              (cond
                  (setq flag 1)
                  (setq flag 1)
                    (entdel arc1)
                    (entdel arc2)
                  (setq s (ssadd))
                  (cond
                      (ssadd arc1 s)
                      (ssadd arc2 s)
                    (vl-cmdf "")
                  |; ;;; for AutoCAD
                    (entdel arc1)
                    (entdel arc2)
                  (setq s (ssadd))
                  (cond
                      (ssadd arc1 s)
                      (ssadd arc2 s)
                    (vl-cmdf "")
                  |; ;;; for AutoCAD
            (if flag
    (if ss
          (cond
              (setq flag 1)
              (setq flag 1)
            (setq flagg 1)
          (vl-cmdf "")
            (entdel arc1)
            (entdel arc2)
          (setq s (ssadd))
          (cond
              (ssadd arc1 s)
              (ssadd arc2 s)
            (vl-cmdf "")
          |; ;;; for AutoCAD
        (if flagg
            (setq k nil)
        (if flag
  (*error* nil)
  • Like 3
EXACTLY WHAT I NEED THANK YOU
