HOW CAN I GET THIS LISP TO WORK ON MULTIPLE POLYLINES AT THE SAME TIME?
ALL I WANT IS BOTH THE COMMAND SHOULD PROMPT ME TO SELECT MULTIPLE POLYLINES. AND SHOULD EXECUTE COMMANDS ON ALL MY POLYLINES AT ONCE.
DIVCUT_MESCUT.lsp
The function one object by using entsel.
If you use ssget and a loop, you can make it do the commands on multiple polylines.
Below is an example of how to make such a loop.
The (princ x) should be replaced with the commands from the function you posted.
Good luck!
; http://www.lee-mac.com/selsetprocessing.html#repeat
(defun c:test2 ( / e i s x )
    (if (setq s (ssget))
            (setq i 0)
            (repeat (sslength s)
                (setq e (ssname s i)
                      x (cdr (assoc 0 (entget e)))
                      i (1+ i)
                (print x)
As dexus says... replace entsel by ssget, and iterate ...
I worked it out for for you.
Nice, code; I can use this myself.
(defun c:divcut (/ ss i ent end div len elst)
	(vl-load-com)
	;; user selects polylines
	(princ "\nSelect polylines")
	(setq ss (ssget (list (cons 0 "LINE,POLYLINE,LWPOLYLINE"))))
	;; user sets number of cuts
	(setq div (getint "\nNumber of divisions: "))
	(setq i 0)
	(while
		(and
			(setq ent (ssname ss i))  ;;  (setq ent (car (entsel)))
			(not (vl-catch-all-error-p
			(setq end
			(vl-catch-all-apply 'vlax-curve-getEndParam (list ent))
			(princ
				(strcat "\nLongueur de l'objet : "
				(rtos (setq len (vlax-curve-getDistAtParam ent end)))
			(< 0 div)
			(setq len (/ len div))
			(vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
			(repeat (1- div)
			(setq
			ent
			(cadr
			(CutCurveAtPoint ent (vlax-curve-getPointAtDist ent len))
			(vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
			(setq i (+ i 1))
		;;(princ "\nEntité non valide")
;; MESCUT
;; Coupe l'objet sélectionné en tronçons de la longueur spécifiée
(defun c:mescut (/ ss i ent end tot len div elst)
	(vl-load-com)
	;; user sets measure length
	(setq len (getdist "\nLength of segment: "))
	(setq i 0)
	(while
		(and
			(setq end
			(princ
			(rtos (setq tot (vlax-curve-getDistAtParam ent end)))
			(< 0 len)
			(setq div (fix (/ tot len)))
			(repeat div
			(setq
			ent
			(cadr
			(setq i (+ i 1))
;; Coupe un objet curviligne au point spécifié
;; Arguments
;; ent : l'objet à couper (ename ou vla-object)
;; pt : le point de coupure (coordonnées WCS)
;; Retour
;; une liste des deux objets créés (ename ou vla-object)
(defun CutCurveAtPoint (ent pt / vl lst cl start end ec os)
	(vl-load-com)
	(and (= (type ent) 'VLA-OBJECT)
		(setq ent (vlax-vla-object->ename ent)
		vl T
	(cond
		((equal pt (vlax-curve-getEndPoint ent) 1e-9)
		(setq lst (list ent nil))
		((equal pt (vlax-curve-getStartPoint ent) 1e-9)
		(setq lst (list nil ent))
		((null (vlax-curve-getParamAtPoint ent pt))
		(T
		(setq start (trans (vlax-curve-getStartPoint ent) 0 1)
		end (trans (vlax-curve-getEndPoint ent) 0 1)
		ec (getvar "cmdecho")
		os (getvar "osmode")
		(setvar "cmdecho" 0)
		(setvar "osmode" 0)
		(if (and (wcmatch (cdr (assoc 0 (entget ent))) "*POLYLINE")
		(= 1 (logand 1 (cdr (assoc 70 (entget ent)))))
		(command "_.break" ent (trans pt 0 1) "@")
		(setq cl (entlast))
		(if (= "POLYLINE" (cdr (assoc 0 (entget ent))))
		(entmake (entget ent))
		(setq vx (entnext ent))
		(while (= "VERTEX" (cdr (assoc 0 (entget vx))))
		(entmake (entget vx))
		(setq vx (entnext vx))
		(entmake '((0 . "SEQEND")))
		(setq cl (entlast)
		po T
		(setq cl (entmakex (entget ent)))
		(command "_.break" ent (trans pt 0 1) end)
		(and po (setq ent (entlast)))
		(command "_.break" cl start (trans pt 0 1))
		(and po (setq cl (entlast)))
		(setvar "cmdecho" ec)
		(setvar "osmode" os)
		(setq lst (list ent cl))
	(if vl
	(mapcar '(lambda (x)
	(if x
	(vlax-ename->vla-object x)
	lst
	lst
@Emmanuel Delay
THANK YOU MAN. THIS IS NOW WORKING THE WAY I WANTED. TOPIC SOLVED.
