I need a lisp that can find maximum value number in a selection contain numbers and text sting
any help will be appreciated
convert strings to numbers with atof
add it to a list
use vl-sort > on list
output first number in list
;;List Maximum Value
(defun C:MValue (/ ss txt lst)
  (if (setq ss (ssget '((0 . "*TEXT"))))
    (foreach txt (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
      (setq value (atof (cdr (assoc 1 (entget txt)))))
      (setq lst (cons value lst))
      (setq lst (vl-sort lst '>))
  (prompt (strcat "\nMaximum Value: " (rtos (car lst) 2)))
--Edit
If your strings contain letters and numbers might have to do a little more before atof
Edited by mhupp
Tank you mhupp that is great
Another way:
(defun c:foo (/ ss)
    (print (apply 'max
		  (mapcar '(lambda (x) (atof (cdr (assoc 1 (entget x)))))
			  (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  • Like 2
1 hour ago, ronjonp said:
Another way:
You misspelled Better 🤣
Just another way to skin the cat :)
  • 1 month later...
add it to a list
--Edit
is there any possibility to keep highest vale and remove remaining? please suggest,.
If you have all the values as a list, largest first you could try a very simple from MHUPPS example
(setq lst (car lst))
of
(setq lst (nth 0 lst))
Both set the variable lst to the first value in that list and deletes all the others
I think RonJonp offered a solution that does the same ,  Replace (print with (setq maxvalue
