looking for a routine to place text at the angle of the entity
What I would like to do is click on the entity (could be a polyline or a line I use both) and place text at the angle of the entity.
I don't need a prompt for the text as I'm going to hard code the value and make a button for each entity type.
Right now my code places the text but only at an already determined angle.
This won't work with some entity's like circles or polylines because they don't have an angle property.
;; Match Angle of selection
(defun C:foo (/ s ss ent)
  (if (and (setq s (car (entsel "\nSelect Entity for reference angle")))
           (setq ss (ssget ":L"))
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (entmod (subst (assoc 50 (entget s))
                     (assoc 50 (entget ent))
                     (entget ent)
Edited by mhupp
You could use something like this to get polyline points, work out the distances, sort to get the closest 2 and from that work out the angle?
;;https://www.cadtutor.net/forum/topic/73414-select-all-points-on-polyline/
(defun c:getplinepoints ( / )
  (setq plent (entsel "\nPick Polyline"))
  (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
  (princ co-ord)
  co-ord
This will get you near with a polyline, however.... it works on the closest points in the polyline, if for example the polyline is 'C' shaped it might select points near the 2 ends but not next to each other if the other 2 points are closer.
(defun c:closestpoints ( / acount rtnlst pt MyAngle)
  (vl-load-com)
  (defun RtD (r) (* 180.0 (/ r pi)))
  (setq acount 0)
  (setq rtnlst (list))
  (setq plent (entsel "\nPick Polyline")) ;;https://www.cadtutor.net/forum/topic/73414-select-all-points-on-polyline/
  (if plent (setq ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
  (setq pt (getpoint "Get Point"))
  (while (< acount (length ptlst))
    (setq rtnlst (append rtnlst (list (list (distance pt (nth acount ptlst)) (nth acount ptlst)))))
    (setq acount (+ acount 1))
  ) ; end while
  (setq rtnlst (vl-sort rtnlst (function (lambda (e1 e2) (< (car e1) (car e2))))) )
  (setq MyAngle (RtD (angle (nth 1 (nth 0 rtnlst)) (nth 1 (nth 1 rtnlst)) )) )
EDIT.
Actually change that idea - angle can be upside down or right way up depends which end the text is nearest to - will need to put in a thingy if angle > 180 deg. then flip the text
Edited by Steven P
Select pline segment. And a label all by Alan Thomson attached.
; Pline segment with angle and length
(defun c:plseg()
(setq plent (entsel "\nSelect Pline  "))
(setvar "osmode" 0)
(setq
      pick (cadr plent)
      plObj (vlax-ename->vla-object (car plent))
      pick2 (vlax-curve-getclosestpointto plobj pick)
      param (vlax-curve-getparamatpoint plObj pick2)
      segment (fix param)
(setq pt1 (nth segment co-ord))
(setq pt2 (nth (+ segment 1) co-ord))
(if (= pt2 nil)(setq pt2 (nth 0 co-ord)))
(setq len (distance pt1 pt2))
(setq ang (angle pt1 pt2))
(alert (strcat "angle is "  (rtos (/ (* ang 180.0) pi) 2 2) " Length is " (rtos len 2 3)))
label pline segments.lsp
