COPY THE CONTENT OF ONE ATTRIBUTE TO OTHERS .... HELP
HELLO
IS THERE ANY LSP ROUTINE THAT CAN COPY THE CONTENT OF ONE ATTRIBUTE TO OTHERS?
IN THE EXAMPLE FILE COPY THE 008 TO THE ATTRIBUTES WITH 007
THANKS
ATRIB TEST.dwg
This does a one to one replace of objects.  Please note I am only selecting the yellow text.
;; Copy item to Multiple locations to replace selection
(defun C:COPYOBJ (/ ent BP SS obj LL UR MPT)
  (vl-load-com)
  (setq obj (vlax-ename->vla-object (setq ent (car (entsel "\nObject to copy: ")))))
  (vla-getboundingbox obj 'minpt 'maxpt)
  (setq BP (mapcar '/ (mapcar '+ (vlax-safearray->list minpt) (vlax-safearray->list maxpt)) '(2 2 2)))
  (if (setq SS (ssget))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
      (setq obj (vlax-ename->vla-object e))
      (setq MPT (mapcar '/ (mapcar '+ (vlax-safearray->list minpt) (vlax-safearray->list maxpt)) '(2 2 2)))
      (vla-delete obj)
      (vl-cmdf "_.Copy" ent "" BP "_non" MPT)
Edited by mhupp
vl-load-com
THANK YOU BUT THE ROUTINE DOES NOT EXECUTE
Added an a to vl-load-com should work now.
Lee MAcs CTX will also do this though you have to select the text to copy into individually
thanks its excellent
Didn't looked at DWG, but according to provided code, I suppose it's designed for copying and replacing normal entities, not specific ones like requested - attributes...
So, can you just select, input desired number, and change textstring to all collected through selection... Either way, it's the same... Sometimes it's better to just do input by keyboard through routine runtime, IMHO...
Is there a reason the block does not have just one attdef ? which can be any text rather than using the Tagstring name ?
  • 1 year later...
