Hello, I really dont know if this is the appropriate board to post this, but Im having an issue regarding to my Dynamic block losing its field everytime I save,
image.png.9760bd968658327631fcb37b8b9654cc.png       image.png.ee6812460e6efa23ce7c76846bdb1708.png
it is showing this error
I always need to run this after i open
(defun c:asd ()
  (setq	ssblck (ssget "x" (list '(0 . "INSERT")))
	lpdtct 0
  (repeat (sslength ssblck)
    (if	(not (eq (vlax-get-property
		   (vlax-ename->vla-object (ssname ssblck lpdtct))
		   'effectivename
		 "OIS-LVL-BLK"
      (progn (setq lpdtct (+ lpdtct 1)))
	(SETQ d1 (ssname ssblck lpdtct)
	      d2 (vlax-ename->vla-object d1)
	      d3 (itoa (vla-get-objectid d2))
	      d4 (vlax-invoke d2 'getattributes)
	      d5 (car d4)		;ffl
	      d6 (cadr d4)		;lvl
	      d7 (vlax-variant-value
		   (vlax-get-property
		     (nth 4 (vlax-invoke d2 'getdynamicblockproperties))
		     'value
	(if (eq d7 1)
	    (command "move" d1 "" '(0 0 0) '(0 1212 0))
	    (vlax-put-property
	      d6
	      'textstring
	      (strcat
		"%<\\AcObjProp Object(%<\\_ObjId "
		d3			    ">%).InsertionPoint \\f "
		"\"%lu2%pt4%pr3"	    "\">%"
	    (vlax-put-property
	      d5
	      'textstring
	      (strcat
		d3			  ">%).Layer \\f "
		"\"%tc1"		  "\">%"
Thank you for anyone who will response.
Sometimes with this type of thing insert the block and as a second step up date it, so you would use (entlast) to get object then put dynamic properties. I know that for blocks must get the id every time as it must reflect the inserted block. You can not copy the block if you have set a ID.
Why dynamic block does it do something special  ?  Where are the values coming from?
You may need to post a real dwg.
Edited by BIGAL
