After selecting a block I want to change attribute values as feed to  lisp file. Can some one help me?
I want to create a lisp file .
Edited by Dayananda
;; Get Attribute Value  -  Lee Mac
;; Returns the value held by the specified tag within the supplied block, if present.
;; blk - [vla] VLA Block Reference Object
;; tag - [str] Attribute TagString
;; Returns: [str] Attribute value, else nil if tag is not found.
(defun LM:vl-getattributevalue ( blk tag )
    (setq tag (strcase tag))
    (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))
Pl. explain me blk-[vla] VLA Block Reference Object
Is that mean the entity name of the block or some other thing.
A few options but looking at this I reckon it is the VLA- entity name, if you scroll down the page there is a version with entity name as well, however Sunday, CAD is off so can't check for you
  • Like 2
You need to explain more, what it is your trying to do. I have for example update title blocks across multiple layouts.
So do you need pick block,  pick attributes ?
Are you aware this gets a attribute details.
(setq att (entget (car (nentsel "\nPick a attribute "))))
 ((-1 . <Entity name: 3d5bc970>) (0 . "ATTRIB") (5 . "D999") (330 . <Entity name: 3d5bd070>) (100 . "AcDbEntity") (67 . 1) (410 . "D01") (8 . "DRGTEXT") (62 . 5) (370 . -1) (100 . "AcDbText") (10 693.8875 56.125 0.0) (40 . 7.0) (1 . "PRELIMINARY DRAWING") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 4) (11 742.1875 59.625 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttribute") (2 . "DRAWING_STATUS") (70 . 0) (73 . 0) (74 . 0) (280 . 0))
1 is text
2 is tagname
  • Thanks 1
can you try this ;
(defun c:asd()
  (setq attlist (vlax-invoke (vlax-ename->vla-object (car (entsel))) 'getattributes)
  	attnumb (- (getint "which attribute number is it?") 1)
        attstrg (getstring "what string??")
  (vlax-put-property (nth attnumb attlist) 'textstring attstrg)
i guess this will give you a basic idea how to access the attribute blocks
(car (entsel)) better as (car (entsel "\nSelect a block ")) like in another post ssget with filter "INSERT" is more reliable as it must be a block use (ssname ss 0) to get block.
need dayananda to provide more info 1 attribute or more, is it to be a random number of attributes to be changed, there are ways of displaying all the tag names and selecting them.
Edited by BIGAL
