Hello everyone! Can anyone helps me with code to draw a circle at specified dimensions. I have added the details in attached file.
Test.dwg
one way is to entmake it, using this basic code:
(entmake '(
  (0 . "CIRCLE") ;make circle
  (62 . 3) ; colour
  (10 4.0 4.0 0.0) ; centre
  (40 . 1.0) ; radius
https://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-D47983BA-1E5D-417D-85B8-6F3DE5F506BA
Pop that into your LISP and modify to suit what you want
If you want to create this using variables, change the (entmake '( to (entmake (list
(setq pt (list 0 0 0)) ;;insertion point
(setq rad 1)
(setq colour 3) ;colour code
(setq layer "0") ; layer, as a string
(entmake (list
  (cons 0 "CIRCLE") ;make circle
  (cons 62 colour) ; colour
  (cons 8 layer) ; colour
  (cons 10 pt) ; centre
  (cons 40 rad) ; radius
and using the entmake codes you can use these for more conrol:
410        Drawn in tab
8            Layer
62         Colour
6           Linetype
48        Linetype Scale
370     Lineweight
So up to you, if you need more help just say....
  • Like 2
Hi Steven. Thanks for your help. Your code is working perfectly. However I also came up with below code.
(defun c:CSP ( / e1 eg1 p10 p11 mp e2 eg2 p20 p21 pt)
  ;; Circle @ Specific Point
  (if (and (setq e1 (car (entsel "\nSelect Line for Midpoint: ")))
           (setq eg1 (entget e1))
           (setq p10 (cdr (assoc 10 eg1)) p11 (cdr (assoc 11 eg1)))
           (setq mp (mapcar '* (mapcar '+ p10 p11) '(0.5 0.5 05)))
           (setq e2 (car (entsel "\nSelect line where Circle will reside: ")))
           (setq eg2 (entget e2))
           (setq p20 (cdr (assoc 10 eg2)) p21 (cdr (assoc 11 eg2)))
           (setq pt (inters mp (mapcar '- mp '(0 1 0)) p20 p21 nil))
      );and
    (command "_.CIRCLE" "_non" pt pause)
  );if
);defun
Another way. Scratch that this doesn't account for the mid point of the first line. and after looking a the example both lines being selected it looks like they are parallel to each other.
(defun c:CSP (/ a b)
  (if (and (setq a (vlax-ename->vla-object (car (entsel "\nSelect the first line: "))))
           (setq b (vlax-ename->vla-object (car (entsel "\nSelect the second line: "))))
      );; and
    (command "_.CIRCLE" "_non" (mapcar '- (vlax-invoke a 'IntersectWith b acExtendNone) '(0 1 0)) pause)
  );; if
Edited by mhupp
Here's a list of most things to draw (line, polyline, circle, ... )
Edited by Emmanuel Delay
  • Like 2
