4 minutes ago, mhupp said:
look to see where your temp files are being made. run the command but don't pick anything their will be a temp .dcl file there. nm ill just convert it for you. give me a sec.
Thank you so much!
little help from a dragon
(defun c:foo (/ n)
  ;;(or (setq n (getint "\nEnter percent:<30>")) (setq n 30))
  (setq fo (open (setq fn (vl-filename-mktemp "" "" ".dcl")) "w"))
  (write-line "AHbutts : dialog \t{" fo)
  (write-line "  label =\"Choose revision\" ;" fo)
  (write-line "    : row\t{" fo)
  (write-line "      : boxed_radio_row\t{" fo)
  (write-line "        : radio_button\t{" fo)
  (write-line "        key = \"Rb1\";" fo)
  (write-line "        label = \"30%\";" fo)
  (write-line "        }" fo)
  (write-line "        spacer_1 ;" fo)
  (write-line "        key = \"Rb2\";" fo)
  (write-line "        label = \"60%\";" fo)
  (write-line "        key = \"Rb3\";" fo)
  (write-line "        label = \"90%\";" fo)
  (write-line "      } " fo)
  (write-line "  ok_only;" fo)
  (write-line "}" fo)
  (close fo)
  (setq dcl_id (load_dialog fn))
  (new_dialog "AHbutts" dcl_id)
  (set_tile "Rb1" "1")
  (action_tile "Rb1" "(setq n \"30%\")(done_dialog)")
  (action_tile "Rb2" "(setq n \"60%\")(done_dialog)")
  (action_tile "Rb3" "(setq n \"90%\")(done_dialog)")
  (action_tile "accept" "(setq n \"30%\")(done_dialog)")
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete fn)
  (foreach l '( "TEST-PP-30%_Design_Review" "TEST-PP-60%_Design_Review" "TEST-PP-90%_Design_Review")
    (vl-catch-all-apply
      'vla-put-freeze
      (list (vlax-ename->vla-object (tblobjname "layer" l))
        (if (wcmatch l (strcat "*" n "*"))
          0
          -1
  (command "_.regen")
Edited by mhupp
updated code
  • Like 2
5 minutes ago, mhupp said:
(defun c:foo (/ n)
  (write-line "}" fo)
  (close fo)
  (new_dialog "AHbutts" (setq d (load_dialog fn)))
  (start_dialog)
  (unload_dialog d)
  (vl-file-delete fo)
    (vl-catch-all-apply
      'vla-put-freeze
        (if (wcmatch l (strcat "*" (itoa n) "*"))
          0
          -1
  (command "_.regen")
Am getting an error :
; error: bad argument type: stringp #<FILE internal>
Oops little more in "Multi radio buttons.lsp" then making the dcl should be fixed now.
Thanksso much for your assistance....
am getting this error now  :
; error: bad argument type: fixnump: "60%"
oops again didn't look closely at @ronjonp super clean code.  😬
just change the following since I'm setting strings with the dcl instead of a number
to
It will be a little harder to "add" things
  (write-line "        key = \"Rb#\";" fo)     ;replace # with a number 1-3 are taken
  (write-line "        label = \"@@@@\";" fo)   ;what it will show
  (action_tile "Rb#" "(setq n \"@@@@\")(done_dialog)")
  also add the layer name to the l list
Edited by mhupp
thank you so much ! working properly now.
Thank you @ronjonpfor the code..
@BIGALfor the radio button
and @mhuppfor merging the 2 lisps together.
thanks so much! appreciate your great help
to
  (write-line "        key = \"Rb#\";" fo)     ;replace # with a number 1-3 are takeng
Am thinking that if I add more choices...i may need to convert to to vertical.
let me see i can try to understand how it works...
thanks again
Column version
(defun c:foo (/ n)
  (write-line "AHbutts : dialog {" fo)
  (write-line "    : row{" fo)
  (write-line "      : boxed_radio_column {" fo)
  • Like 3
IMO DCL is not needed for this simple task. If you format the input correctly and have DYNMODE set to 1, it makes for a pretty clean interface.
(defun c:foo (/ a n)
  (initget 0 (setq a "30 60 90"))
  (setq
    n (cond ((getkword (strcat "\nSelect Option [" (vl-string-translate " " "/" a) "] <30>: ")))
	    ("30")
  (foreach l '("TEST-PP-30%_Design_Review" "TEST-PP-60%_Design_Review" "TEST-PP-90%_Design_Review")
    (vl-catch-all-apply
      'vla-put-freeze
	      0
	      -1
  (command "_.regen")
Edited by ronjonp
  • Like 4
  (setq
	    ("30")
    (vl-catch-all-apply
      'vla-put-freeze
	      0
	      -1
  (command "_.regen")
Thanks @ronjonp
i have DYNMODE set to 0 as it slows down my computer...
still working great though.
edit :
when i tested on a xref'd title block it return an error
Select Option [30/60/90] <30>:
bad argument type: VLA-OBJECT nil
When working on the native file it's working fine...
Edited by CAD_Noob
So toggle it for just this command. 🤣
The error "bad argument type: VLA-OBJECT nil" is probably because the layer doesn't exist in that drawing. added an if statement to check for layer. if missing will let you know.
--edit
Quote
when i tested on a xref'd title block it return an error :
Layers that are in the xref have the name of the xref in front like this xref named "typical-motel-room"
--edit
had to build a list of layers that contain the strings in check (old l list) from there builds a new l list of the layers that need to be frozen or thawed.
(defun c:foo (/ a n check lay match l)
  (setvar 'DYNMODE 1)  ;set dynmode @ pointer
  (setq n
    (cond
      ((getkword (strcat "\nSelect Option [" (vl-string-translate " " "/" a) "] <30>: "))) ( "30")
  (setvar 'DYNMODE 0)  ;turn off dynmode
  (foreach check '("TEST-PP-30%_Design_Review" "TEST-PP-60%_Design_Review" "TEST-PP-90%_Design_Review")
    (foreach lay (Table "layer")
      (if (wcmatch lay (strcat "*" check "*"))
        (setq match (cons lay match))
  (foreach l match
    (vl-catch-all-apply 'vla-put-freeze
        (if (wcmatch l (strcat "*" n "*")) 0 -1)
  (command "_.regen")
;Written By Michael Puckett.
(defun Table (s / d r)
  (while (setq d (tblnext s (null d)))
    (setq r (cons (cdr (assoc 2 d)) r))
Edited by mhupp
  • Like 2
--edit
This will fix that
(if (tblsearch "Layer" (strcat "*" l))
so instead of searching for layers names that only match whats in quotes "TEST-PP-30%_Design_Review" it will search for layers that end whats in quotes.
  (setq n
    (cond
      ((getkword (strcat "\nSelect Option [" (vl-string-translate " " "/" a) "] <30>: "))) ("30")
    (if (tblsearch "Layer" (strcat "*" l));check if layer exists
        (list (vlax-ename->vla-object (tblobjname "layer" (strcat "*" l)))
      (prompt (strcat "\nLayer " l " not in drawing"))
  (command "_.regen")
the layers are there...but reports show that its not...
lol this is what happens when you don't test code before posting.
Had to build a list of layers that contain the strings in check (old l list) from there builds a new l list of the layers that need to be frozen or thawed.
--edit
no more missing message
code updated above
Edited by mhupp
--edit
code updated above
thank you so much! working perfectly now.
Multi Radio buttons supports vertical or horizontal choice no need to redo code.
(ah:butts ahdef "V"
(ah:butts ahdef "H"
