; Equation Graph by autolisp - 2022.06.20 exceed
; command list : yx1, yx2, yx3, yx4, yx5, yx6, y2x2 (circle)
; not a complete routine just for fun
; https://www.cadtutor.net/forum/topic/75463-equation-graph-by-autolisp/
; If it's for your homework, it's not a good choice to use it.
; Use a program that draws accurate graphs.  matlab, etc. Excel is also good.
(defun c:yx1 ( / a b startx endx steps deltax ptlist pt mspace tmp myobj ylist )
  (princ "\n y = Ax + B ")
  (setq a (getreal "\n Input A = "))
  (setq b (getreal "\n Input B = "))
  (setq startx (getreal "\n Input Start X = "))
  (setq endx (getreal "\n Input End X = "))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq deltax (/ (- endx startx) steps))
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (* a x) b))
    (setq ylist (cons y ylist))
    (setq pt (list x y 0.0))
    (setq ptlist (cons pt ptlist))
    (setq x (+ x deltax))
  (setq ylist (vl-sort ylist '<))
  (setq ymin (car ylist))
  (setq ymax (last ylist))
  (setq ptlist (reverse ptlist))
  ; https://www.afralisp.net/archive/methods/list/addpolyline_method.htm
  (setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
  (setq ptlist (apply 'append ptlist))
  (if (= (rem (length ptlist) 3) 0)
      (setq tmp (vlax-make-safearray vlax-vbDouble (cons 0 (- (length ptlist) 1)) ) )
      (vlax-safearray-fill tmp ptlist)
      (setq myobj (vla-addPolyline mspace tmp))
    (princ "\nerror: Polyline could not be created")
  (vlax-put-property myobj 'color 3)
  (ex:drawaxis startx endx ymin ymax steps)
(defun c:yx2 ( / a b c startx endx steps deltax ptlist pt mspace tmp myobj ylist )
  (princ "\n y = Ax^2 + Bx + C")
  (setq c (getreal "\n Input C = "))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (* a x x) (* b x) c))
(defun c:yx3 ( / a b c d startx endx steps deltax ptlist pt mspace tmp myobj ylist )
  (princ "\n y = Ax^3 + Bx^2 + Cx + D")
  (setq d (getreal "\n Input D = "))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (* a x x x) (* b x x) (* c x) d))
(defun c:yx4 ( / a b c d e startx endx steps deltax ptlist pt mspace tmp myobj ylist )
  (princ "\n y = Ax^4 + Bx^3 + Cx^2 + Dx + E ")
  (setq e (getreal "\n Input E = "))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (* a x x x x) (* b x x x) (* c x x) (* d x) e))
(defun c:yx5 ( / a b c d e f startx endx steps deltax ptlist pt mspace tmp myobj ylist )
  (princ "\n y = Ax^5 + Bx^4 + Cx^3 + Dx^2 + Ex + F ")
  (setq f (getreal "\n Input F = "))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (* a x x x x x) (* b x x x x) (* c x x x) (* d x x) (* e x) f))
(defun c:yx6 ( / a b c d e f g startx endx steps deltax ptlist pt mspace tmp myobj ylist )
  (princ "\n y = Ax^6 + Bx^5 + Cx^4 + Dx^3 + Ex^2 + Fx + G ")
  (setq g (getreal "\n Input G = "))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (* a x x x x x x) (* b x x x x x) (* c x x x x) (* d x x x) (* e x x) (* f x) g))
(defun c:y2x2 ( / a b c startx endx steps deltax ptlist pt mspace tmp myobj xlist ylist xmin xmax ymin ymax )
  (princ "\n (x - A)^2 + (y - B)^2 = C^2")
  (setq startx (- a c))
  (setq endx (+ a c))
  (setq steps 100)
  (cond
    ((<= startx endx)
      (setq x startx)
    ((> startx endx)
      (setq x endx)
      (setq endx startx)
      (setq startx x)
  (setq xlist '())
  (setq ylist '())
  (setq ptlist '())
  (repeat (+ steps 1)
    (setq y (+ (sqrt (abs (- (+ (- (* c c) (* x x)) (* 2 a x)) (* a a)))) b))
    (setq xlist (cons x xlist))
  (setq x startx)
  (repeat (+ steps 1)
    (setq y (- (* 2 b) y))
  (setq xlist (vl-sort xlist '<))
  (setq xmin (car xlist))
  (setq xmax (last xlist))
  (ex:drawaxis xmin xmax ymin ymax steps)
(defun ex:drawaxis ( xmin xmax ymin ymax steps / deltax xaxisline yaxisline xaxisarrow1 xaxisarrow2 xaxisarrow3 xaxisarrow4 yaxisarrow1 yaxisarrow2 yaxisarrow3 yaxisarrow4 xaxistext1 xaxistext2 yaxistext1 yaxistext2 )
  (setq deltax (/ (- xmax xmin) steps))
  (setq xaxisline (vla-addline mspace (vlax-3d-point (list (- xmin (* (/ steps 10) deltax)) 0 0))(vlax-3d-point (list (+ xmax (* (/ steps 10) deltax)) 0 0))))
  (setq yaxisline (vla-addline mspace (vlax-3d-point (list 0 (- ymin (* (/ steps 10) deltax)) 0))(vlax-3d-point (list 0 (+ ymax (* (/ steps 10) deltax)) 0))))
  (setq xaxisarrow1 (vla-addline mspace (vlax-3d-point (list (- xmin (* (/ steps 20) deltax)) (- 0 (* (/ steps 100) deltax)) 0))(vlax-3d-point (list (- xmin (* (/ steps 10) deltax)) 0 0))))
  (setq xaxisarrow2 (vla-addline mspace (vlax-3d-point (list (- xmin (* (/ steps 20) deltax)) (+ 0 (* (/ steps 100) deltax)) 0))(vlax-3d-point (list (- xmin (* (/ steps 10) deltax)) 0 0))))
  (setq xaxisarrow3 (vla-addline mspace (vlax-3d-point (list (+ xmax (* (/ steps 20) deltax)) (- 0 (* (/ steps 100) deltax)) 0))(vlax-3d-point (list (+ xmax (* (/ steps 10) deltax)) 0 0))))
  (setq xaxisarrow4 (vla-addline mspace (vlax-3d-point (list (+ xmax (* (/ steps 20) deltax)) (+ 0 (* (/ steps 100) deltax)) 0))(vlax-3d-point (list (+ xmax (* (/ steps 10) deltax)) 0 0))))
  (setq yaxisarrow1 (vla-addline mspace (vlax-3d-point (list (- 0 (* (/ steps 100) deltax)) (- ymin (* (/ steps 20) deltax)) 0))(vlax-3d-point (list 0 (- ymin (* (/ steps 10) deltax)) 0))))
  (setq yaxisarrow2 (vla-addline mspace (vlax-3d-point (list (+ 0 (* (/ steps 100) deltax)) (- ymin (* (/ steps 20) deltax)) 0))(vlax-3d-point (list 0 (- ymin (* (/ steps 10) deltax)) 0))))
  (setq yaxisarrow3 (vla-addline mspace (vlax-3d-point (list (- 0 (* (/ steps 100) deltax)) (+ ymax (* (/ steps 20) deltax)) 0))(vlax-3d-point (list 0 (+ ymax (* (/ steps 10) deltax)) 0))))
  (setq yaxisarrow4 (vla-addline mspace (vlax-3d-point (list (+ 0 (* (/ steps 100) deltax)) (+ ymax (* (/ steps 20) deltax)) 0))(vlax-3d-point (list 0 (+ ymax (* (/ steps 10) deltax)) 0))))
  (setq xaxistext1 (vla-AddText mspace "+x" (vlax-3d-point (list (+ xmax (* (/ steps 8) deltax)) 0 0)) (* (/ steps 20) deltax)))
  (vlax-put-property xaxistext1 'alignment 9)
  (setq xaxistext2 (vla-AddText mspace "-x" (vlax-3d-point (list (- xmin (* (/ steps 8) deltax)) 0 0)) (* (/ steps 20) deltax)))
  (vlax-put-property xaxistext2 'alignment 11)
  (setq yaxistext1 (vla-AddText mspace "-y" (vlax-3d-point (list 0 (- ymin (* (/ steps 8) deltax)) 0)) (* (/ steps 20) deltax)))
  (vlax-put-property yaxistext1 'alignment 7)
  (setq yaxistext2 (vla-AddText mspace "+y" (vlax-3d-point (list 0 (+ ymax (* (/ steps 8) deltax)) 0)) (* (/ steps 20) deltax)))
  (vlax-put-property yaxistext2 'alignment 13)
  (setq bar (* (/ steps 10) deltax))
  (setq barlen (/ bar 6))
  (setq index2 0)
  (repeat 11
    (setq xbar (vla-addline mspace (vlax-3d-point (list (+ xmin (* bar index2)) barlen 0))(vlax-3d-point (list (+ xmin (* bar index2)) (* barlen -1) 0))))
    (setq xbartext (vla-AddText mspace (rtos (+ xmin (* bar index2)) 2 0) (vlax-3d-point (list (+ (+ xmin (* bar index2)) (/ barlen 2)) (- 0 (/ barlen 2)) 0)) (/ (* (/ steps 20) deltax) 2)))
    (vlax-put-property xbartext 'alignment 6)
    (setq index2 (+ index2 1))
  (setq index2 0)
  (repeat 11
    (setq ybar (vla-addline mspace (vlax-3d-point (list barlen (+ ymin (* bar index2)) 0))(vlax-3d-point (list (* barlen -1) (+ ymin (* bar index2)) 0))))
    (setq ybartext (vla-AddText mspace (rtos (+ ymin (* bar index2)) 2 0) (vlax-3d-point (list (- 0 (/ barlen 2)) (+ (+ ymin (* bar index2)) (/ barlen 4)) 0)) (/ (* (/ steps 20) deltax) 2)))
    (vlax-put-property ybartext 'alignment 14)
command list
yx1 - linear equation  y = Ax + B
yx2 - quadratic equation y = Ax^2 + Bx + C
yx3 - cubic equation y = Ax^3 + Bx^2 + Cx + D
yx4 - biquadratic equation y = Ax^4 + Bx^3 + Cx^2 + Dx + E
yx5 - quintic equation y = Ax^5 + Bx^4 + Cx^3 + Dx^2 + Ex + F
yx6 - 6th y = Ax^6 + Bx^5 + Cx^4 + Dx^3 + Ex^2 + Fx + G
y2x2 - circle equation (x-a)^2 + (y-b)^2 = c^2
This is a simple routine that just connects points with polylines and no curves. This is not an exact graph.
Edited by exceed
  • Like 4
