When I am using UCS by object and for that selecting the text it shows Z axis on text. but in the text properties it is not there if I change the value of Z also nothing changing same problem exist.
Not only the UCS, when i am using Lee Mac Align Text to Curve it is not coming properly. for that I am fixing the problem am using Lee Mac Text2MText Upgraded with single selection or explode the text and making again Text2MText. while flattening the text is self-exploding.
for this how can i remove all text z axis value at single time.....????
Test.dwgFetching info...
  On 6/18/2022 at 7:29 AM, exceed said:
how about to use FLATTEN
Expand
if i use this text will explode so i have to do Text2MText
