exceed Posted June 17, 2022 Share Posted June 17, 2022 ; EX:NUM->COL - 2022.06.17 exceed ; change numbers to alphabet numbers. (like EXCEL column) ; example ) A, B, C ~ Y, Z, AA ZZ, AAA ~ ZZZ, AAAA ~ ZZZZ, AAAAA ~ ZZZZZ ; allowed numbers 1 to 12356630 ; ; How to use ; (EX:NUM->COL number) (defun EX:NUM->COL ( c / answer c1 c2 c3 c4 c5 ) (setq c (- c 1)) (cond ((< c 0) ; case for under 0 value (setq answer (strcat "out of range")) ) ((and (>= c 0) (< c 26)) ; case for 1 ~ 26 (= A ~ Z) (setq c1 (+ c 1)) (setq answer (strcat (chr (+ 64 c1)))) ) ((and (>= c 26) (< c (+ 26 (* 26 26))) ) ; case for 26 ~ 702 (= AA ~ ZZ) (setq c (- c 26)) (setq c2 (fix (/ c 26))) (setq c1 (- c (* c2 26))) (setq c1 (+ c1 1)) (setq c2 (+ c2 1)) (setq answer (strcat (chr (+ 64 c2)) (chr (+ 64 c1)))) ) ((and (>= c (+ 26 (* 26 26))) (< c (+ 26 (* 26 26) (* 26 26 26)))) ; case for 702 ~ 18278 (= AAA ~ ZZZ) (setq c (- c (+ 26 (* 26 26)))) (setq c3 (fix (/ c (* 26 26)) ) ) (setq c2 (fix (/ (- c (* c3 26 26)) 26))) (setq c1 (- (- c (* c3 26 26)) (* c2 26))) (setq c1 (+ c1 1)) (setq c2 (+ c2 1)) (setq c3 (+ c3 1)) (setq answer (strcat (chr (+ 64 c3)) (chr (+ 64 c2)) (chr (+ 64 c1)))) ) ((and (>= c (+ 26 (* 26 26) (* 26 26 26))) (< c (+ 26 (* 26 26) (* 26 26 26) (* 26 26 26 26)) )) ; case for 18278 ~ 475254 (= AAAA (setq c (- c (+ 26 (* 26 26) (* 26 26 26)))) (setq c4 (fix (/ c (* 26 26 26)))) (setq c3 (fix (/ (- c (* c4 26 26 26)) (* 26 26)))) (setq c2 (fix (/ (- (- c (* c4 26 26 26)) (* c3 26 26)) 26))) (setq c1 (- (- (- c (* c4 26 26 26)) (* c3 26 26)) (* c2 26))) (setq c1 (+ c1 1)) (setq c2 (+ c2 1)) (setq c3 (+ c3 1)) (setq c4 (+ c4 1)) (setq answer (strcat (chr (+ 64 c4)) (chr (+ 64 c3)) (chr (+ 64 c2)) (chr (+ 64 c1)))) ) ((and (>= c (+ 26 (* 26 26) (* 26 26 26) (* 26 26 26 26))) (< c (+ 26 (* 26 26) (* 26 26 26) (* 26 26 26 26) (* 26 26 26 26 26)))) ; case for 475254 ~ 12356630 (setq c (- c (+ 26 (* 26 26) (* 26 26 26) (* 26 26 26 26)))) (setq c5 (fix (/ c (* 26 26 26 26)))) (setq c4 (fix (/ (- c (* c5 26 26 26 26)) (* 26 26 26)))) (setq c3 (fix (/ (- (- c (* c5 26 26 26 26)) (* c4 26 26 26)) (* 26 26)))) (setq c2 (fix (/ (- (- (- c (* c5 26 26 26 26)) (* c4 26 26 26)) (* c3 26 26)) 26))) (setq c1 (- (- (- (- c (* c5 26 26 26 26)) (* c4 26 26 26)) (* c3 26 26)) (* c2 26))) (setq c1 (+ c1 1)) (setq c2 (+ c2 1)) (setq c3 (+ c3 1)) (setq c4 (+ c4 1)) (setq c5 (+ c5 1)) (setq answer (strcat (chr (+ 64 c5)) (chr (+ 64 c4)) (chr (+ 64 c3)) (chr (+ 64 c2)) (chr (+ 64 c1)))) ) ((>= c (+ 26 (* 26 26) (* 26 26 26) (* 26 26 26 26) (* 26 26 26 26 26))) ; case for over 12356630 (setq answer (strcat "out of range")) ) ) answer ) ; EX:COL->NUM - 2022.06.17 exceed ; reverse function of EX:NUM->COL ; allowed alphabets A to ZZZZZ ; ; How to use ; (EX:COL->NUM string) (defun EX:COL->NUM ( c / answer clen cflag clist index catom clistlen ) (setq c (strcase c)) (setq clen (strlen c)) (if (and (> clen 0) (< clen 6)) (progn (setq cflag 0) (setq clist '()) (setq index 1) (repeat clen (setq catom (ascii (substr c index 1))) (if (and (>= catom 65) (<= catom 90)) (setq clist (cons (- catom 64) clist)) (setq cflag 1) ) (setq index (+ index 1)) ) (if (= cflag 0) (progn (setq clist (reverse clist)) (setq clistlen (length clist)) (cond ((= clistlen 1) (setq answer (nth 0 clist)) ) ((= clistlen 2) (setq answer (+ (* (nth 0 clist) 26) (nth 1 clist))) ) ((= clistlen 3) (setq answer (+ (* (nth 0 clist) 26 26) (* (nth 1 clist) 26) (nth 2 clist))) ) ((= clistlen 4) (setq answer (+ (* (nth 0 clist) 26 26 26) (* (nth 1 clist) 26 26) (* (nth 2 clist) 26) (nth 3 clist))) ) ((= clistlen 5) (setq answer (+ (* (nth 0 clist) 26 26 26 26) (* (nth 1 clist) 26 26 26) (* (nth 2 clist) 26 26) (* (nth 3 clist) 26) (nth 4 clist))) ) ) ) (progn (setq answer "Non-alphabetic impurities are mixed.") ) ) ) (progn (setq answer "Only 1 ~ 5 digits Alphabet can be calculated.") ) ) answer ) i have organized parts of this code for use elsewhere. https://www.cadtutor.net/forum/topic/74681-cad-output-excel-specified-page/?do=findComment&comment=591539 It seems like it could be made more concisely, but at my level, this is the limit. (EX:NUM->COL number) (EX:COL->NUM string) test code is below (defun c:test ( / a ) (princ "\n ================== ") (setq a 1) (repeat 40 (princ "\n input = ") (princ a) (princ " / NUM->COL = ") (princ (EX:NUM->COL a)) (princ " / COL->NUM = ") (princ (EX:COL->NUM (EX:NUM->COL a))) (setq a (+ a 1)) ) (princ "\n ================== ") (setq a 690) (repeat 20 (princ "\n input = ") (princ a) (princ " / NUM->COL = ") (princ (EX:NUM->COL a)) (princ " / COL->NUM = ") (princ (EX:COL->NUM (EX:NUM->COL a))) (setq a (+ a 1)) ) (princ "\n ================== ") (setq a 18270) (repeat 20 (princ "\n input = ") (princ a) (princ " / NUM->COL = ") (princ (EX:NUM->COL a)) (princ " / COL->NUM = ") (princ (EX:COL->NUM (EX:NUM->COL a))) (setq a (+ a 1)) ) (princ "\n ================== ") (setq a 475240) (repeat 20 (princ "\n input = ") (princ a) (princ " / NUM->COL = ") (princ (EX:NUM->COL a)) (princ " / COL->NUM = ") (princ (EX:COL->NUM (EX:NUM->COL a))) (setq a (+ a 1)) ) (princ "\n ================== ") (setq a 12356625) (repeat 10 (princ "\n input = ") (princ a) (princ " / NUM->COL = ") (princ (EX:NUM->COL a)) (princ " / COL->NUM = ") (princ (EX:COL->NUM (EX:NUM->COL a))) (setq a (+ a 1)) ) (princ "\n ================== ") (princ) ) and test result is below ================== input = 1 / NUM->COL = A / COL->NUM = 1 input = 2 / NUM->COL = B / COL->NUM = 2 input = 3 / NUM->COL = C / COL->NUM = 3 input = 4 / NUM->COL = D / COL->NUM = 4 input = 5 / NUM->COL = E / COL->NUM = 5 input = 6 / NUM->COL = F / COL->NUM = 6 input = 7 / NUM->COL = G / COL->NUM = 7 input = 8 / NUM->COL = H / COL->NUM = 8 input = 9 / NUM->COL = I / COL->NUM = 9 input = 10 / NUM->COL = J / COL->NUM = 10 input = 11 / NUM->COL = K / COL->NUM = 11 input = 12 / NUM->COL = L / COL->NUM = 12 input = 13 / NUM->COL = M / COL->NUM = 13 input = 14 / NUM->COL = N / COL->NUM = 14 input = 15 / NUM->COL = O / COL->NUM = 15 input = 16 / NUM->COL = P / COL->NUM = 16 input = 17 / NUM->COL = Q / COL->NUM = 17 input = 18 / NUM->COL = R / COL->NUM = 18 input = 19 / NUM->COL = S / COL->NUM = 19 input = 20 / NUM->COL = T / COL->NUM = 20 input = 21 / NUM->COL = U / COL->NUM = 21 input = 22 / NUM->COL = V / COL->NUM = 22 input = 23 / NUM->COL = W / COL->NUM = 23 input = 24 / NUM->COL = X / COL->NUM = 24 input = 25 / NUM->COL = Y / COL->NUM = 25 input = 26 / NUM->COL = Z / COL->NUM = 26 input = 27 / NUM->COL = AA / COL->NUM = 27 input = 28 / NUM->COL = AB / COL->NUM = 28 input = 29 / NUM->COL = AC / COL->NUM = 29 input = 30 / NUM->COL = AD / COL->NUM = 30 input = 31 / NUM->COL = AE / COL->NUM = 31 input = 32 / NUM->COL = AF / COL->NUM = 32 input = 33 / NUM->COL = AG / COL->NUM = 33 input = 34 / NUM->COL = AH / COL->NUM = 34 input = 35 / NUM->COL = AI / COL->NUM = 35 input = 36 / NUM->COL = AJ / COL->NUM = 36 input = 37 / NUM->COL = AK / COL->NUM = 37 input = 38 / NUM->COL = AL / COL->NUM = 38 input = 39 / NUM->COL = AM / COL->NUM = 39 input = 40 / NUM->COL = AN / COL->NUM = 40 ================== input = 690 / NUM->COL = ZN / COL->NUM = 690 input = 691 / NUM->COL = ZO / COL->NUM = 691 input = 692 / NUM->COL = ZP / COL->NUM = 692 input = 693 / NUM->COL = ZQ / COL->NUM = 693 input = 694 / NUM->COL = ZR / COL->NUM = 694 input = 695 / NUM->COL = ZS / COL->NUM = 695 input = 696 / NUM->COL = ZT / COL->NUM = 696 input = 697 / NUM->COL = ZU / COL->NUM = 697 input = 698 / NUM->COL = ZV / COL->NUM = 698 input = 699 / NUM->COL = ZW / COL->NUM = 699 input = 700 / NUM->COL = ZX / COL->NUM = 700 input = 701 / NUM->COL = ZY / COL->NUM = 701 input = 702 / NUM->COL = ZZ / COL->NUM = 702 input = 703 / NUM->COL = AAA / COL->NUM = 703 input = 704 / NUM->COL = AAB / COL->NUM = 704 input = 705 / NUM->COL = AAC / COL->NUM = 705 input = 706 / NUM->COL = AAD / COL->NUM = 706 input = 707 / NUM->COL = AAE / COL->NUM = 707 input = 708 / NUM->COL = AAF / COL->NUM = 708 input = 709 / NUM->COL = AAG / COL->NUM = 709 ================== input = 18270 / NUM->COL = ZZR / COL->NUM = 18270 input = 18271 / NUM->COL = ZZS / COL->NUM = 18271 input = 18272 / NUM->COL = ZZT / COL->NUM = 18272 input = 18273 / NUM->COL = ZZU / COL->NUM = 18273 input = 18274 / NUM->COL = ZZV / COL->NUM = 18274 input = 18275 / NUM->COL = ZZW / COL->NUM = 18275 input = 18276 / NUM->COL = ZZX / COL->NUM = 18276 input = 18277 / NUM->COL = ZZY / COL->NUM = 18277 input = 18278 / NUM->COL = ZZZ / COL->NUM = 18278 input = 18279 / NUM->COL = AAAA / COL->NUM = 18279 input = 18280 / NUM->COL = AAAB / COL->NUM = 18280 input = 18281 / NUM->COL = AAAC / COL->NUM = 18281 input = 18282 / NUM->COL = AAAD / COL->NUM = 18282 input = 18283 / NUM->COL = AAAE / COL->NUM = 18283 input = 18284 / NUM->COL = AAAF / COL->NUM = 18284 input = 18285 / NUM->COL = AAAG / COL->NUM = 18285 input = 18286 / NUM->COL = AAAH / COL->NUM = 18286 input = 18287 / NUM->COL = AAAI / COL->NUM = 18287 input = 18288 / NUM->COL = AAAJ / COL->NUM = 18288 input = 18289 / NUM->COL = AAAK / COL->NUM = 18289 ================== input = 475240 / NUM->COL = ZZZL / COL->NUM = 475240 input = 475241 / NUM->COL = ZZZM / COL->NUM = 475241 input = 475242 / NUM->COL = ZZZN / COL->NUM = 475242 input = 475243 / NUM->COL = ZZZO / COL->NUM = 475243 input = 475244 / NUM->COL = ZZZP / COL->NUM = 475244 input = 475245 / NUM->COL = ZZZQ / COL->NUM = 475245 input = 475246 / NUM->COL = ZZZR / COL->NUM = 475246 input = 475247 / NUM->COL = ZZZS / COL->NUM = 475247 input = 475248 / NUM->COL = ZZZT / COL->NUM = 475248 input = 475249 / NUM->COL = ZZZU / COL->NUM = 475249 input = 475250 / NUM->COL = ZZZV / COL->NUM = 475250 input = 475251 / NUM->COL = ZZZW / COL->NUM = 475251 input = 475252 / NUM->COL = ZZZX / COL->NUM = 475252 input = 475253 / NUM->COL = ZZZY / COL->NUM = 475253 input = 475254 / NUM->COL = ZZZZ / COL->NUM = 475254 input = 475255 / NUM->COL = AAAAA / COL->NUM = 475255 input = 475256 / NUM->COL = AAAAB / COL->NUM = 475256 input = 475257 / NUM->COL = AAAAC / COL->NUM = 475257 input = 475258 / NUM->COL = AAAAD / COL->NUM = 475258 input = 475259 / NUM->COL = AAAAE / COL->NUM = 475259 ================== input = 12356625 / NUM->COL = ZZZZU / COL->NUM = 12356625 input = 12356626 / NUM->COL = ZZZZV / COL->NUM = 12356626 input = 12356627 / NUM->COL = ZZZZW / COL->NUM = 12356627 input = 12356628 / NUM->COL = ZZZZX / COL->NUM = 12356628 input = 12356629 / NUM->COL = ZZZZY / COL->NUM = 12356629 input = 12356630 / NUM->COL = ZZZZZ / COL->NUM = 12356630 input = 12356631 / NUM->COL = out of range / COL->NUM = Only 1 ~ 5 digits Alphabet can be calculated. input = 12356632 / NUM->COL = out of range / COL->NUM = Only 1 ~ 5 digits Alphabet can be calculated. input = 12356633 / NUM->COL = out of range / COL->NUM = Only 1 ~ 5 digits Alphabet can be calculated. input = 12356634 / NUM->COL = out of range / COL->NUM = Only 1 ~ 5 digits Alphabet can be calculated. ================== I've been wrong on this problem twice before, sadly so please let me know if you find anything wrong number in 1 ~ 12356630 Quote Link to comment Share on other sites More sharing options...
