John.Red Posted June 15, 2022 Share Posted June 15, 2022 (edited) Hello to all! I've been following this forum and generally this site for a long time ago but I have just registered (my English is a bit poor to write topics and participate) because now i need your help with a lisp code that i found recently. Below is the code, it creates tables from picked text objects. What i need is after you pick each text (before it goes to a cell) to change it's color to red (or any other color) because when I have a bunch of text objects I need to know which of them went to a table. Can someone please help me with that? Thanks in advance. (defun c:AHxcol ( / pt1 numrows numcolumns rowheight colwidth ent doc curspace obj objtable col) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq curspace (vla-get-modelspace doc)) ; now do table (setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table: "))) (setq numcolumns (getint "how many columns")) (setq txtsz (getreal "enter text size")) (setq numrows 2) (setq rowheight (* 1.5 txtsz)) (setq colwidth (* 10 txtsz)) (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "TABLE") (setq x 1) (repeat numcolumns (vla-settext objtable 1 (- x 1) (strcat "COLUMN " (rtos x 2 0))) (setq x (+ x 1)) ) (setq objtable (vlax-ename->vla-object (entlast))) (vla-InsertRows objtable numrows txtsz 1) (setq col 0) (while (setq ent (entsel "pick text object")) (setq obj (vlax-ename->vla-object (car ent))) (if (= (vla-get-objectname obj) "AcDbText") (progn (vla-settext objtable numrows col (vla-get-textstring obj)) (setq col (+ col 1)) (if (= col numcolumns) (progn (setq col 0) (setq numrows (+ numrows 1)) (vla-InsertRows objtable numrows (* txtsz 1.5) 1) ) ) ) ) ) (vla-SetTextHeight objtable (+ acDataRow acHeaderRow acTitleRow) txtsz) (vla-SetAlignment objtable acDataRow acMiddleCenter) (vlax-release-object objtable) (princ) ) (c:AHxcol) Edited June 15, 2022 by SLW210 Added Code Tags! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 15, 2022 Share Posted June 15, 2022 Please use Code Tags for your Code in the future. Quote Link to comment Share on other sites More sharing options...
John.Red Posted June 15, 2022 Author Share Posted June 15, 2022 Sorry, i didn't know how to do it, next time i will. 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 15, 2022 Share Posted June 15, 2022 (edited) try this. (defun c:AHxcol (/ k txtsz x pt1 numrows numcolumns rowheight colwidth ent doc curspace obj objtable col) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq curspace (vla-get-modelspace doc)) ; now do table (setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table: "))) (setq numcolumns (getint "Number of columns: ")) (setq txtsz (getreal "Text size: ")) (setq numrows 2) (setq rowheight (* 1.5 txtsz)) (setq colwidth (* 10 txtsz)) (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "TABLE") (setq x 0) (repeat numcolumns (vla-settext objtable 1 x (strcat "COLUMN " (itoa (setq x (1+ x))))) ) (setq objtable (vlax-ename->vla-object (entlast))) (vla-InsertRows objtable numrows txtsz 1) (setq col 0) (while (setq ent (car (entsel "Pick text :"))) (if (= (vla-get-objectname (setq obj (vlax-ename->vla-object ent))) "AcDbText") (progn (vla-put-color obj 1) (vla-settext objtable numrows col (vla-get-textstring obj)) (setq col (+ col 1)) (if (= col numcolumns) (progn (setq col 0) (setq numrows (+ numrows 1)) (vla-InsertRows objtable numrows (* txtsz 1.5) 1) ) ) ) ) ) (vla-SetTextHeight objtable (+ acDataRow acHeaderRow acTitleRow) txtsz) (vla-SetAlignment objtable acDataRow acMiddleCenter) (setq x 0) (repeat numcolumns (if (/= (vla-gettext objtable numrows x) "") (setq k 1)) (setq x (1+ x)) ) (if (eq k 1) (progn) (vla-deleterows objtable numrows numrows) ) (vlax-release-object objtable) (princ) ) -edit @John.Red update the code to delete the last row if nothing is inputted (aka blank) Edited June 15, 2022 by mhupp Code Updated Quote Link to comment Share on other sites More sharing options...
John.Red Posted June 15, 2022 Author Share Posted June 15, 2022 My friend you are awesome! Thank you so much for your effort, this is exactly what i want. 1 Quote Link to comment Share on other sites More sharing options...
John.Red Posted June 17, 2022 Author Share Posted June 17, 2022 I have updated the code, better now that i don't have to delete the last row. Works perfectly, thanks again. May i ask, is it possible to pick values from an existing table? I have many tables where i want to copy certain rows to a new table. What i do now with this lisp (and your help on it) is to copy all these tables, double explode to get values as plain text and then make a table by the lisp (with same columns) and pick each text from a row. It could be time saver if i could pick these values directly from the tables instead of copy-explode-explode. If cannot be done is ok, i can do my job with the above method, but if is something that can be done "easily" it could be a great help. Thanks again for your effort. Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 17, 2022 Share Posted June 17, 2022 Yes using but i can't get them to turn red. I'm sure your fine with that. (defun c:AHxcol (/ k txtsz x pt1 numrows numcolumns rowheight colwidth ent doc curspace obj objtable col) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq curspace (vla-get-modelspace doc)) ; now do table (setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table: "))) (setq numcolumns (getint "Number of columns: ")) (setq txtsz (getreal "Text size: ")) (setq numrows 2) (setq rowheight (* 1.5 txtsz)) (setq colwidth (* 10 txtsz)) (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "TABLE") (setq x 0) (repeat numcolumns (vla-settext objtable 1 x (strcat "COLUMN " (itoa (setq x (1+ x))))) ) (setq objtable (vlax-ename->vla-object (entlast))) (vla-InsertRows objtable numrows txtsz 1) (setq col 0) (while (setq ent (car (nentsel "Pick text : "))) (if (member (vla-get-objectname (setq obj (vlax-ename->vla-object ent))) '("AcDbMText" "AcDbText")) (progn (vla-put-color obj 1) (vla-settext objtable numrows col (vla-get-textstring obj)) (setq col (1+ col)) (if (= col numcolumns) (progn (setq col 0) (setq numrows (1+ numrows)) (vla-InsertRows objtable numrows (* txtsz 1.5) 1) ) ) ) ) ) (vla-SetTextHeight objtable (+ acDataRow acHeaderRow acTitleRow) txtsz) (vla-SetAlignment objtable acDataRow acMiddleCenter) (setq x -1) (repeat numcolumns (if (/= (vla-gettext objtable numrows (setq x (1+ x))) "") (setq k 1)) ) (if (eq k 1) (progn) (vla-deleterows objtable numrows numrows) ) (vlax-release-object objtable) (princ) ) Quote Link to comment Share on other sites More sharing options...
John.Red Posted June 17, 2022 Author Share Posted June 17, 2022 It keeps asking for a text object. When i pick a cell the command ends and leaves a blank table. Quote Link to comment Share on other sites More sharing options...
John.Red Posted June 17, 2022 Author Share Posted June 17, 2022 Oops, sorry. I thought you changed the code to use cells instead text. Don't mind, i can work with this lisp as it is. Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 17, 2022 Share Posted June 17, 2022 4 minutes ago, John.Red said: Oops, sorry. I thought you changed the code to use cells instead text. Don't mind, i can work with this lisp as it is. nope just added an n to entsel to make nentsel so you can select nested text inside tables or blocks. Quote Link to comment Share on other sites More sharing options...
John.Red Posted June 17, 2022 Author Share Posted June 17, 2022 Oh, i see.. Is more important though to know which text i have selected (by turning red) to be sure that everything i want is on the new table than picking from a set of tables. I will stick to copy-exploding method to extract the info i want. Thank you! Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 17, 2022 Share Posted June 17, 2022 1 hour ago, John.Red said: Oh, i see.. Is more important though to know which text i have selected (by turning red) to be sure that everything i want is on the new table than picking from a set of tables. Try this. works on text, mtext and tables ;;----------------------------------------------------------------------------;; ;; CREATE TABLE AND ADD SELECTED TEXT TO IT (defun c:AHxcol (/ k txtsz x pt1 numrows numcolumns rowheight colwidth ent doc curspace obj objtable col) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq curspace (vla-get-modelspace doc)) ; now do table (setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table: "))) (setq numcolumns (getint "Number of columns: ")) (setq txtsz (getreal "Text size: ")) (setq numrows 2) (setq rowheight (* 1.5 txtsz)) (setq colwidth (* 10 txtsz)) (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "TABLE") (setq x 0) (repeat numcolumns (vla-settext objtable 1 x (strcat "COLUMN " (itoa (setq x (1+ x))))) ) (setq objtable (vlax-ename->vla-object (entlast))) (vla-InsertRows objtable numrows txtsz 1) (setq col 0) (while (setq ent (entsel "Pick text : ")) (cond ((member (vla-get-objectname (setq obj (vlax-ename->vla-object (car ent)))) '( "AcDbMText" "AcDbText")) (progn (vla-put-color obj 1) (vla-settext objtable numrows col (vla-get-textstring obj)) (setq col (1+ col)) (if (= col numcolumns) (progn (setq col 0) (setq numrows (1+ numrows)) (vla-InsertRows objtable numrows (* txtsz 1.5) 1) ) ) ) ) ((eq (vla-get-objectname (setq obj (vlax-ename->vla-object (car ent)))) "AcDbTable") (setq x (_hit-test (cadr ent) obj)) (setq COLOBJ (vla-getinterfaceobject (vlax-get-acad-object) "AutoCAD.AcCmColor.16")) (vla-put-colorindex COLOBJ 1) (vla-SetCellContentColor obj (car x) (cadr x) COLOBJ) (vla-settext objtable numrows col (vla-getText obj (car x) (cadr x))) (setq col (1+ col)) (if (= col numcolumns) (progn (setq col 0) (setq numrows (1+ numrows)) (vla-InsertRows objtable numrows (* txtsz 1.5) 1) ) ) ) ) ) (vla-SetTextHeight objtable (+ acDataRow acHeaderRow acTitleRow) txtsz) (vla-SetAlignment objtable acDataRow acMiddleCenter) (setq x -1) (repeat numcolumns (if (/= (vla-gettext objtable numrows (setq x (1+ x))) "") (setq k 1)) ) (if (eq k 1) (progn) (vla-deleterows objtable numrows numrows) ) (vlax-release-object objtable) (princ) ) ;;----------------------------------------------------------------------------;; ;; FIND ROW AND COLUMN OF SELECTED TEXT IN TABLE (defun _hit-test (pt obj / vd) (setq pt (vlax-3D-point (trans pt 1 0)) vd (vlax-3D-point (trans (getvar 'VIEWDIR) 1 0)) ) (if (eq :vlax-true (vla-hittest obj pt vd 'r 'c)) (list r c) ) ) 1 Quote Link to comment Share on other sites More sharing options...
